14.07.2010, 19:05 | #1 |
paruvella: AIF – Outbound with a number of Records per XML
Источник: http://paruvella.spaces.live.com/Blo...4DB0!545.entry
============== Again I am back with some AIF stuff. Assume that if we have a requirement like, we need to send at least 10 records per XML as an outbound. Have a look on the following example which gives an idea, how we can send 10 or some number of records in an XML as an outbound. X++: static void AIFSendChAccForRangeRec(Args _args) { AxdSendContext axdSendContext = AxdSendContext::construct(); AifConstraint aifConstraint = new AifConstraint() ; AifConstraintList aifConstraintList = new AifConstraintList(); AifActionId actionId; AifEndpointList endpointList; Query query; QueryBuildDataSource queryBuildDataSource; QueryBuildRange qbr; RecId start; RecId end; LedgerTable ledgerTable; ; //reading lowest recordId for a specific criteria select firstonly RecId from ledgerTable where ledgerTable.AccountPlType == LedgerAccountType::Heading; start = ledgerTable.RecId; end = start + 100; // add some value to the recordId. This increment value we can change depends on req. query = new Query(queryStr(AxdChartOfAccounts)); AxdSend::removeChildDs(query); queryBuildDataSource = query.dataSourceTable(tablenum(LedgerTable)); queryBuildDataSource.addRange(fieldnum(LedgerTable, AccountPlType)).value(QueryValue(LedgerAccountType::Heading)); qbr = queryBuildDataSource.addRange(fieldnum(LedgerTable, RecId)); //here adding the records range condition, to filter the no.of records to send in XML qbr.value(strfmt('( (%1 >= %2) && (%1 <= %3) )', fieldstr(LedgerTable, RecId), start, end)); actionId = AifSendService::getDefaultSendAction(classnum(LedgerChartOfAccountsService), AifSendActionType::SendByQuery); aifConstraint.parmType(AifConstraintType::NoConstraint); aifConstraintList.addConstraint(aifConstraint); endpointList = AifSendService::getEligibleEndpoints(actionId, aifConstraintList); //implemented the AIF-Outbound using query object AifSendService::submitFromQuery(actionId, endpointList, query, AifSendMode::Async); }
