Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 14.09.2010, 16:49   #1
ist is offline
ist
Ax2009 - Missed FilterByField and FilterBySelection on some grid columns
Hi, everyone,
I have a form with two dtasources - InventTable and CustVendExternalItem. CustVendExternalItem datasource has joined with the InventTable datasource as JoingMode = OutherJoin. The problem is that FilterByField and FilterBySelection are not appear in the context menu for the fields from CustVendExternalItem. I have the same form in Ax40 SP1, but the problem does not exist.
Is there any way to display this elements on the context menu on the this fields in ax 2009?
Regards,
ist.
Старый 15.09.2010, 11:26   #2
No, I am afraid not.
Support for sorting/filtering outer joined fields is still not present in AX 2009.
AX6 however provides that support, so "stay tuned"
Старый 15.09.2010, 12:57   #3
twilight is offline
twilight
873 / 237 (9) ++++++
Сообщение от ist Посмотреть сообщение
Don't understand.
Existed in Ax 4, removed in AX 2009 and will be added in Ax 6?
Why was removed in AX 2009?
I could tell you, but then I would have to bill you.
Старый 15.09.2010, 15:03   #4
I don't think it ever worked.
At least I remember hitting a lot of walls when trying to do this on previous AX releases.
Старый 15.09.2010, 15:25   #5
oip is offline
oip
Axapta
2,564 / 1416 (53) ++++++++
It does work in Ax 3.0 and Ax 4.0. In Ax 2009 filtering is also ok if you use buttons at the top of the form. The only thing is that there are no FIlterByField and FilterBySelection items in the context menu. And btw there are absolutely no problems with sorting.
Олег.
Старый 15.09.2010, 17:08   #6
It does work in Ax 3.0 and Ax 4.0. In Ax 2009 filtering is also ok if you use buttons at the top of the form. The only thing is that there are no FIlterByField and FilterBySelection items in the context menu. And there are absolutely no problems with sorting.
Hmm, strange.
I remember otherwise.
Guess I am wrong.
Старый 15.09.2010, 23:59   #7
ist is offline
ist
I don't think so.
As you can see on the screenshot, buttons on the top of the form does not work for fields of the outered datasource!
Regards,
Миниатюры
Последний раз редактировалось ist; 16.09.2010 в 01:08.
Часовой пояс GMT +3, время: 17:50.
