Старый 24.09.2010, 01:06   #1
25,643 / 848 (80) +++++++
Kashperuk Ivan: Tutorial: Undocumented behavior of kernel functions min()/max()
Источник: http://kashperuk.blogspot.com/2010/0...havior-of.html
I was recently reviewing some code written to be shipped with AX6, and noticed an unfamiliar pattern being used in it. I investigated a bit deeper, and turns out it actually works fine on previous versions of AX as well.
I am talking about 2 kernel functions for finding the maximum or minimum of the specified values.
The signature of these methods is shown on the below image:
As you can see, it takes 2 arguments of anytype, and returns an anytype which is the largest of the two values. But it can accept much more than 2 arguments, even though it is not documented as such.
I wrote a small job to showcase this behavior. The code is provided below. You can also download it from my SkyDrive Dynamics AX share.
static void Tutorial_MinMaxFunctions(Args _args)
    #define.ArraySize(11)
    Random  rand = new Random();
    int     counter;
    int     arrayInt[#ArraySize];
    str     arrayIntAsString;
    int     arrayIntMaxValue;
    int     arrayIntMinValue;
    for (counter = 1; counter <= #ArraySize; counter++)
        arrayInt[counter] = rand.nextInt();
        if (arrayIntAsString)
            arrayIntAsString += ', ';
        arrayIntAsString += int2str(arrayInt[counter]);
    info("Generated array of integers: " + arrayIntAsString);
    info("The typical way to find a maximum is by looping through all the values one by one, calling the comparison function multiple times");
    arrayIntMaxValue = minint();
    arrayIntMinValue = maxint();
        arrayIntMaxValue = max(arrayIntMaxValue, arrayInt[counter]);
        arrayIntMinValue = min(arrayIntMinValue, arrayInt[counter]);
    info(strfmt("Max.value: %1 and Min.value: %2", int2str(arrayIntMaxValue), int2str(arrayIntMinValue)));
    info("Using max and min with 11 arguments works just as well");
    arrayIntMaxValue = max(arrayInt[1], arrayInt[2], arrayInt[3], arrayInt[4], arrayInt[5], arrayInt[6], arrayInt[7], arrayInt[8], arrayInt[9], arrayInt[10], arrayInt[11]);
    arrayIntMinValue = min(arrayInt[1], arrayInt[2], arrayInt[3], arrayInt[4], arrayInt[5], arrayInt[6], arrayInt[7], arrayInt[8], arrayInt[9], arrayInt[10], arrayInt[11]);
    info("Note that comparing an integer and a real also works, as well as outputing the results straight into an infolog message");
    info(max(12, 12.001));
Another interesting point is that it can actually accept different types of arguments, for example, a real and an integer, as shown above. And it actually returns an anytype, which implicitly gets converted to a string when sent to the infolog.
Disclaimer: Since this is not a documented feature, it can theoretically change in the future releases, but I doubt it in this particular case.
Kashperuk Ivan: Tutorial: refresh, reread, research, executeQuery - which one to use? Blog bot DAX Blogs 20 04.04.2017 13:23
Kashperuk Ivan: Casing and text search/comparison tutorial Blog bot DAX Blogs 6 25.02.2010 15:41
Kashperuk Ivan: Kernel functions exposed through BC.NET Blog bot DAX Blogs 0 25.11.2009 19:05
Kashperuk Ivan: tutorial_Form_Dynalink (a small tutorial on dynalinks) Blog bot DAX Blogs 0 22.08.2007 17:00
Kashperuk Ivan: Dynamics AX Tutorials - Tutorial 2 - Classes\Box Blog bot DAX Blogs 0 25.04.2007 22:23
Часовой пояс GMT +3, время: 09:28.
