Старый 20.11.2003, 10:35   #5
raz is offline
raz
Аватар для raz
1,500 / 1098 (40) ++++++++
Решил рискнуть и написать такой Job
Для Axapta 3.0
static void Fill_InventItemLocation(Args _args)
SysOperationProgress    progressDlg;
InventItemLocation      InventItemLocation;
InventLocation          InventLocation;
InventDimSetup          InventDimSetup;
InventTable             InventTable;
InventBatch             InventBatch;
ConfigTable             ConfigTable;
InventColor             InventColor;
InventSize              InventSize;
InventDim               InventDim;
boolean                 _Config_Color_SizeLoopConfigLoopColorLoopSize;
#aviFiles
if (box::yesNo("Заполнить InventItemLocation?",DialogButton::No,"Сделайте выбор","") == DialogButton::Yes)
progressDlg = new SysOperationProgress();
progressDlg.setAnimation(#AviFormLetter);
progressDlg.setCaption("Подождите...");
progressDlg.setText("Заполняется InventItemLocation");
progressDlg.setCount(1);
        while
select InventTable where InventTable.ItemType != ItemType::Service
            while
select InventLocation
_Config InventDimSetup::find(InventTable.DimGroupId,fieldname2id(tablename2id("InventDim"),"ConfigId")).Active;
_Color  InventDimSetup::find(InventTable.DimGroupId,fieldname2id(tablename2id("InventDim"),"InventColorId")).Active;
_Size   InventDimSetup::find(InventTable.DimGroupId,fieldname2id(tablename2id("InventDim"),"InventSizeId")).Active;
LoopConfig true;
LoopColor  true;
LoopSize   true;
select ConfigTable where ConfigTable.ItemId == InventTable.ItemId;
                while (
LoopConfig)
select InventColor where InventColor.ItemId == InventTable.ItemId;
                    while (
LoopColor)
select InventSize where InventSize.ItemId == InventTable.ItemId;
                        while (
LoopSize)
InventDim.clear();
                            if (
_ConfigInventDim.configId      ConfigTable.ConfigId;
                            if (
_Color)  InventDim.InventColorId InventColor.InventColorId;
                            if (
_Size)   InventDim.InventSizeId  InventSize.InventSizeId;
InventDim.InventLocationId InventLocation.InventLocationId;
InventDim InventDim::findOrCreate(InventDim);
select InventItemLocation where InventItemLocation.ItemId      == InventTable.ItemId &&
InventItemLocation.inventDimId == InventDim.inventDimId;
                            if (
InventItemLocation.RecId == 0)
InventItemLocation.clear();
InventItemLocation.ItemId       InventTable.ItemId;
InventItemLocation.InventDimId  InventDim.InventDimId;
InventItemLocation.insert();
progressDlg.incCount();
LoopSize = (InventSize.RecId != 0);
                            if (
LoopSizenext InventSize;
LoopColor = (InventColor.RecId != 0);
                        if (
LoopColornext InventColor;
LoopConfig = (ConfigTable.RecId != 0);
                    if (
LoopConfignext ConfigTable;
Планирование номенклатуры с типом Основное средство AlexeyBP DAX: Функционал 19 29.01.2009 07:42
Не могу изменить название номенклатуры slava09 DAX: Функционал 14 21.03.2007 18:01
Импорт списка номенклатуры Роман Кошелев DAX: База знаний и проекты 2 15.06.2006 16:52
Список допустимых комбинаций для номенклатуры ola DAX: Функционал 3 22.12.2004 17:58
Проблемы настройки прав доступа пользователям axot DAX: Администрирование 25 16.05.2002 10:47
Часовой пояс GMT +3, время: 17:45.
