Старый 09.12.2010, 02:13   #1
dynamicsaxtraining: How to access field in a table using this field id
Источник: http://www.dynamicsaxtraining.com/kn...-this-field-id
To do this you could use next construction:
myTable.( filednum( myTable, myField ) ) = “XXX”;
This is the same as
myTable.myField = “XXX”;
Example:
Field AccountNum from CustTable have id 1. Then statement CustTable.(1) = “4000” – will initialize field AccountNum with value “4000”.
You could also use this feature while working with record of type Common.
Example:
Common common; CustTable custTable; ; select custTable where custTable.AccountNum == "4000"; common = custTable; info( common.( fieldnum( custTable, Name ) ) );The output of running this code will be the info log with a message “Light and Design”, Where “Light and Design” – name of the customer with id “4000″.
dynamicsaxtraining: How to get original value for table fields during record modification Blog bot DAX Blogs 0 06.12.2010 23:11
dynamicsaxtraining: How dynamically change data source field properties Blog bot DAX Blogs 0 06.12.2010 23:11
dynamicsaxtraining: How to make data from temporary table available in form’s grid Blog bot DAX Blogs 0 04.12.2010 01:11
DynamicsAxSCM: The InventTrans table. Explore various field usages. Blog bot DAX Blogs 0 09.11.2010 19:10
Часовой пояс GMT +3, время: 11:53.
