#1 |
Date range in StringEdit control
Hi guys,
How can I realize range in StringEdit control similar as the screenshot? Any example would be great. Regards, |
#2 |
Ищущий знания...
hi, ist!
Here is an example: Цитата:
"Item1".."Item100"
"Страх перед возможностью ошибки не должен отвращать нас от поисков истины." (с) С Уважением, Елизаров Артем |
#3 |
Maybe I have not explained properly. I want to choose a value from the date lookup, then write '..' and then select the second value from the date lookup.
#4 |
Ищущий знания...
maybe:
#5 |
Maybe AX is stuck on the strange date format you have: YYYY.MM.DD. What weird country are you from? ![]() |
#6 |
Set property string control ReplaceOnLookup = No.
#7 |
