Старый 10.02.2011, 15:46   #10
Буденый is offline
Буденый
Код плагина:
using System;
using System.Collections.Generic;
using Microsoft.Win32;
using Microsoft.Crm.Sdk;
using Microsoft.Crm.SdkTypeProxy;
using Microsoft.Crm.SdkTypeProxy.Metadata;
using Microsoft.Crm.Sdk.Query;
namespace AKAutoNumber
    public class AKAutoNumber : IPlugin
        private string _secureInformation;
        private string _unsecureInformation;
        private static object _sync = new object();
        public AKAutoNumber(string unsecureInfo, string secureInfo)
            _secureInformation = secureInfo;
            _unsecureInformation = unsecureInfo;
        // Related SDK topic: Writing a Plug-in
        public void Execute(IPluginExecutionContext context)
            DynamicEntity entity = null;
            if (context.InputParameters.Properties.Contains(ParameterName.Target) &&
               context.InputParameters.Properties[ParameterName.Target] is DynamicEntity)
                entity = (DynamicEntity)context.InputParameters.Properties[ParameterName.Target];
            else
                return;
            try
                lock (_sync)
                    // simple query to get incremental settings for this entity
                    CrmAuthenticationToken token = new CrmAuthenticationToken();
                    token.AuthenticationType = AuthenticationType.AD;
                    token.OrganizationName = context.OrganizationName;
                    CrmService service = new CrmService();
                    service.UseDefaultCredentials = true;
                    service.Url = (string)(Registry.LocalMachine.OpenSubKey("Software\\Microsoft\\MSCRM").GetValue("ServerUrl")) + "/2007/crmservice.asmx";
                    service.CrmAuthenticationTokenValue = token;
                    IncrementalNumbering setting = IncrementalNumbering.GetSettings(service, entity.Name);
                    if (setting != null && !entity.Properties.Contains(setting.PropertyName))
                        int next = setting.CurrentPosition + 1;
                        StringProperty increment = new StringProperty(setting.PropertyName,setting.Prefix.ToString()+ next.ToString());
                        entity.Properties.Add(increment);
                        // keep track of the latest id inside the custom entity
                        setting.Increment(service, next);
            catch (System.Web.Services.Protocols.SoapException ex)
                throw new InvalidPluginExecutionException(
                    String.Format("An error occurred in the {0} plug-in.",
                       this.GetType().ToString()),
                    ex);
Код вспомагательного класа
using System;
using System.Linq;
using System.Text;
    public class IncrementalNumbering
        public const string SchemaName = "do_universalnumber";
        public class Fields
            public const string Id = "do_universalnumberid";
            public const string EntityName = "do_name";
            public const string PropertyName = "do_attribute";
            public const string CurrentPosition = "do_count";
            public const string Prefix = "do_prefix";
        public Guid Id { get; set; }
        public string EntityName { get; set; }
        public string PropertyName { get; set; }
        public string Prefix { get; set; }
        public int CurrentPosition { get; set; }
        public IncrementalNumbering() { }
        public IncrementalNumbering(DynamicEntity entity)
            this.Id = (entity.Properties[Fields.Id] as Key).Value;
            this.EntityName = entity.Properties[Fields.EntityName].ToString();
            this.PropertyName = entity.Properties[Fields.PropertyName].ToString();
            this.Prefix = entity.Properties[Fields.Prefix].ToString();
            this.CurrentPosition = (entity.Properties[Fields.CurrentPosition] as CrmNumber).Value;
        public void Increment(CrmService service, int next)
            this.CurrentPosition = next; // set before calling ToDynamic
            TargetUpdateDynamic target = new TargetUpdateDynamic();
            target.Entity = this.ToDynamic();
            UpdateRequest request = new UpdateRequest();
            request.Target = target;
            service.Execute(request);
        // see if there are any increment settings for this entity
        public static IncrementalNumbering GetSettings(CrmService service, string entityName)
            IncrementalNumbering setting = null;
            QueryExpression query = new QueryExpression();
            query.EntityName = IncrementalNumbering.SchemaName;
            query.ColumnSet = new AllColumns();
            query.Criteria = new FilterExpression();
            query.Criteria.FilterOperator = LogicalOperator.And;
            ConditionExpression condition1 = new ConditionExpression();
            condition1.AttributeName = IncrementalNumbering.Fields.EntityName;
            condition1.Operator = ConditionOperator.Equal;
            condition1.Values = new object[] { entityName };
            query.Criteria.AddCondition(condition1);
            RetrieveMultipleRequest request = new RetrieveMultipleRequest();
            request.Query = query;
            request.ReturnDynamicEntities = true;
            RetrieveMultipleResponse response = service.Execute(request) as RetrieveMultipleResponse;
            BusinessEntityCollection results = response.BusinessEntityCollection;
            if (results.BusinessEntities.Count > 0) // no error checkig to see if there are 2 incrementors set for the same entity
                setting = new IncrementalNumbering(results.BusinessEntities[0] as DynamicEntity);
            return setting;
        // should include rest of the fields, but leave it for now
        public DynamicEntity ToDynamic()
            DynamicEntity entity = new DynamicEntity(IncrementalNumbering.SchemaName);
            PropertyCollection properties = new PropertyCollection();
            properties.Add(new KeyProperty(Fields.Id, new Key(this.Id)));
            properties.Add(new CrmNumberProperty(Fields.CurrentPosition, new CrmNumber(this.CurrentPosition)));
            entity.Properties = properties;
            return entity;
Тип файла: rar AKAutoNumber.rar (2.2 Кб, 144 просмотров)
Плагин на изменение подразделения пользователя xmarina Dynamics CRM: Разработка 6 23.11.2010 15:04
не срабатывает плагин Shamasher Dynamics CRM: Разработка 5 13.10.2010 10:55
Плагин на создании Заказа Krom Dynamics CRM: Разработка 4 04.08.2010 14:48
Тип сущности, использующей плагин Казарин Александр Dynamics CRM: Разработка 2 02.04.2009 20:29
Как зарегить плагин на смену State? Alir Dynamics CRM: Разработка 8 24.11.2008 12:06
Часовой пояс GMT +3, время: 19:53.
