Старый 19.02.2011, 20:26   #9
Sergikrus is offline
Sergikrus
Angry
Сообщение от EvgenijM Посмотреть сообщение
function GetAttributeValueByEntityId(entityName, entytiId, attributeName)
    var xml = '' +
    '[?xml version=`1.0` encoding=`utf-8`?]' + '\r\n' +
    '[soap:Envelope xmlns:soap=`http://schemas.xmlsoap.org/soap/envelope/` xmlns:xsi=`http://www.w3.org/2001/XMLSchema-instance` xmlns:xsd=`http://www.w3.org/2001/XMLSchema`]' + '\r\n' +
    ' [soap:Body]' + '\r\n' +
    ' [entityName xmlns=`http://schemas.microsoft.com/crm/2006/WebServices`]' + entityName + '[/entityName]' + '\r\n' +
    ' [id xmlns=`http://schemas.microsoft.com/crm/2006/WebServices`]' + entytiId + '[/id]' + '\r\n' +
    ' [columnSet xmlns=`http://schemas.microsoft.com/crm/2006/WebServices` xmlns:q=`http://schemas.microsoft.com/crm/2006/Query` xsi:type=`q:ColumnSet`]' + '\r\n' +
    ' [q:Attributes]' + '\r\n' +
    ' [q:Attribute]' + attributeName + '[/q:Attribute]' + '\r\n' +
    ' [/q:Attributes]' + '\r\n' +
    ' [/columnSet]' + '\r\n' +
    ' [/soap:Body]' + '\r\n' +
    '[/soap:Envelope]' +
    xml = xml.replace(/\[/gi, String.fromCharCode(60));
    xml = xml.replace(/\]/gi, String.fromCharCode(62));
    xml = xml.replace(/\`/gi, String.fromCharCode(34));
    var xmlHttpRequest = new ActiveXObject('Msxml2.XMLHTTP');
    xmlHttpRequest.Open('POST', '/mscrmservices/2006/CrmService.asmx', false);
    xmlHttpRequest.setRequestHeader('SOAPAction','http://schemas.microsoft.com/crm/2006/WebServices/Retrieve');
    xmlHttpRequest.setRequestHeader('Content-Type', 'text/xml; charset=utf-8');
    xmlHttpRequest.setRequestHeader('Content-Length', xml.length);
    xmlHttpRequest.send(xml);
    var doc = xmlHttpRequest.responseXML;
//    alert(xmlHttpRequest.responseText);
    var retValue = '';
    if (doc.selectSingleNode('//RetrieveResult/' + attributeName) != null) retValue = doc.selectSingleNode('//RetrieveResult/' + attributeName).text;
    return retValue;
Использовать в OnChange поля продукта, например:
var oProduct = crmForm.all.productid;
if (oProduct.DataValue != null && oProduct.DataValue[0] != null)
    crmForm.all.SOME_OTHER_FIELD.DataValue = GetAttributeValueByEntityId('product', oProduct.DataValue[0].id, 'PRODUCT_ATTRIBUTE_NAME');
Сообщение с веб-страницы
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap:Body>
<soap:Fault>
<faultcode>soap:Client</faultcode> <faultstring>System.Web.Services.Protocols.SoapException: Сервер не распознал заголовок HTTP SOAPAction: http://srv/mscrmservices/2006/WebServices/Retrieve. at System.Web.Services.Protocols.Soap11ServerProtocolHelper.RouteRequest() at System.Web.Services.Protocols.SoapServerProtocol.Initialize() at System.Web.Services.Protocols.ServerProtocolFactory.Create(Type type, HttpContext context, HttpRequest request, HttpResponse response, Boolean&amp; abortProcessing)</faultstring>
<detail />
</soap:Fault>
</soap:Body>
</soap:Envelope>
ОК
Уже кучу способов перепробовал, а результат один . Подскажите пожалуйста, в чем моя ошибка?
Получить данные из формы родителя DinDim Dynamics CRM: Разработка 3 19.02.2009 15:38
Как пограммно получить имя сущности Lookup-а ZooY Dynamics CRM: Разработка 6 21.07.2008 18:17
Обновление поля во внешней сущности через JScript Sergio_che Dynamics CRM: Разработка 4 06.06.2008 23:44
Как взять текстовое значение из поля LookUp tatra Dynamics CRM: Разработка 2 21.11.2007 08:20
Два лукапа одной сущности нга одной форме Dr.Kurpatov Dynamics CRM: Разработка 16 22.01.2007 20:23
Часовой пояс GMT +3, время: 05:28.
