Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 11.08.2011, 12:07   #5
cyrus is offline
cyrus
OntargIT
22 / 19 (1) ++
Proper solution for connecting WM terminals to DAX is to use AIF Web services. There are some issues though.
1) WCF is supported only in CF3.5
2) BasicHTTPBinding shall be used. wsHttpBinding is not supported in CF3.5
3) Binding security shall be set to Transport since None is not supported by AIF (it shall know particular web-service user) and TransportCredentialsOnly is not supported by CF3.5
3) IIS shall be configured to support SSL
4) Certificate shall be installed on each consuming device, similar to cross-domain security
If you make security setup properly the connection will be plain simple just like in this example.
Последний раз редактировалось cyrus; 11.08.2011 в 13:00.
aif, axapta, business connector, integration, windows mobile
Dynamics Mobile: How to code your own barcode enabled tasklets (Motorola and Intermec devices) Blog bot DAX Blogs 1 03.06.2014 06:34
emeadaxsupport: Starting Dynamics AX 2009 is launching Windows Installer for Microsoft Axapta 3.0 Blog bot DAX Blogs 0 27.01.2010 13:05
Dynamics Mobile: How to enable barcode scanning on existing Microsoft Dynamics Mobile tasklets Blog bot DAX Blogs 0 07.04.2009 08:05
Ruslan Goncharov: How to get list of all open windows and their names in AX Blog bot DAX Blogs 0 29.12.2007 19:50
Часовой пояс GMT +3, время: 07:59.
