Старый 12.08.2011, 14:20   #3
oip is offline
oip
Axapta
2,564 / 1416 (53) ++++++++
Так вроде бы уже давно в лицензии на Акс такого ограничения нет. Когда-то действительно была фраза:
The Licensee shall have the right to make copies of the Program for the following purposes only: 1) copies for archival or backup purposes, 2) one (1) copy for development and test purposes
Потом была вот такая редакция (еще во времена 4.0):
You may make multiple copies of the software for backup and testing purposes, so long as such copies are not used in production. Your backup copies may be hosted by a third party on your behalf.
Сейчас действующая редакция для 3.0 - 2009 такая:
You may make multiple copies of the software for backup, development and testing purposes, so long as such copies are not used in production and the development is for your internal use only. Your backup copies may be hosted by a third party on your behalf.
Для 2012:
You may make multiple copies of the software for backup, development and testing purposes, so long as such copies are not used in production and the development is for your internal use only. Your backup copies may be hosted by a third party on your behalf. You may use copies only to create instances of the software.
Последний раз редактировалось oip; 12.08.2011 в 14:27. Причина: Добавил про 2012
За это сообщение автора поблагодарили: fed (2), gl00mie (2).
ax2012, как правильно
Microsoft Dynamics AX 2012 White Paper: Developing Solutions in a Shared AOS Development Environment Vadik DAX: База знаний и проекты 0 31.07.2011 18:32
mfp: Development books on Dynamics AX Blog bot DAX Blogs 3 10.02.2011 14:43
dynamics-ax-dev: Copying a Production Environment into a Development/Test Environment Blog bot DAX Blogs 0 02.12.2010 00:11
Jim Wang: Build a handy Dynamics CRM development environment Blog bot Dynamics CRM: Blogs 0 15.08.2009 19:06
Microsoft Dynamics CRM Team Blog: Setting Up Your CRM Development Environment Blog bot Dynamics CRM: Blogs 0 22.07.2009 09:05
Часовой пояс GMT +3, время: 16:05.
