Старый 21.08.2011, 15:13   #1
kranthiax: You can correct a posted packing slip in AX 2012
Источник: http://kranthiax.blogspot.com/2011/0...g-slip-in.html
In the previous versions, it was very difficult to correct a packing slip. you were supposed to reverse the original packing with negative quantity then posting a new packing slip with corrected data.
AX 2012 comes with a good functionality which can really help you to correct or cancel a posted packing slip both in sales and purchases.
After posting the purchase packing slip
go to the Receipt and click on Product Receipt, where you can see the list of packing slips posted. select the packing slip which you want to correct and click on correct.
The same form that is used for posting the original packing slip will get opened, now do the necessary changes to that packing slip(example: quantity) and post the packing slip. Now you can observe the changes to the posted packing slip.
Старый 22.08.2011, 11:59   #2
twilight is offline
twilight
890 / 241 (10) ++++++
Аксапта приближается к 1С по части коррекции документов? )
I could tell you, but then I would have to bill you.
kranthiax: New And Deprecated Features of AX 2012 Blog bot DAX Blogs 0 26.06.2011 02:21
dynamics-ax: Modeling the world, with Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.01.2011 09:11
Часовой пояс GMT +3, время: 06:16.
