Старый 26.08.2011, 01:13   #1
sumitsaxfactor: Browsing Folders for Files on 64-bit Server Side Implementation (Batch Run)
Источник: http://sumitsaxfactor.wordpress.com/...ion-batch-run/
I am sure all of us have had a requirement where we were supposed to process a folder for specific file pattern / all file pattern and process these files.
This scenario is very prominent during integration of different applications with AX.
I scenarios where this process is run manually or on client side, we use the standard methods provided by Microsoft in WinApi class (FindFirstFile, FindNextFile, FindClose).
These methods in turn use the FindFirstFile, FindNextFile and FindClose methods defined in Kernel32 dll.
Now these methods are not provided on Server Side implementation of WinApi namely WinApiServer. But you can copy  these methods from WinApi to WinApiServer and use them as required.
These methods work fine on any 32-bit OS on both client side and server side.
But the real issue comes when you are using these methods on 64-bit systems and that too on server side.
The reason being we need some redirection that needs to be done. I will speak about this re-direction in a separate blog post as I am still working on making this work inside Ax.
But other method that I found was to use System.IO class.
Here is a sample code with proper comments to make you understand.
server public static void getFiles()
    System.IO.DirectoryInfo directoryInfo;
    System.IO.FileInfo[]    fileList;
    System.IO.FileInfo      file;
    System.Exception        e;
    System.String           moveName, fromName;
    int i;
    int fileCount;
    str axMoveName, axFromName;
    InterOpPermission   perm;
    FileIOPermission    filePerm;
    FilePath            searchFilePath;
    FileName            moveFileName;
    //Check if the folder exists
    filePerm = new FileIOPermission(@"\AX_InBound\", ‘r’);
    filePerm.assert();
    if (!WinApiServer::fileExists(@"\AX_InBound\", true))
        throw error("Path not found");
    CodeAccessPermission::revertAssert();
    //Check if the archive folder exists
    filePerm = new FileIOPermission(@"\AX_Archive\", ‘r’);
    filePerm.assert();
    if (!WinApiServer::fileExists(@"\AX_Archive\", true))
        throw error("Archive Path not found");
    //Check the permission for CLR InterOp
    perm = new InterOpPermission(InteropKind::ClrInterop);
    perm.assert();
    try
        //Traverse to the inbound folder and search file
        searchFilePath = @"\AX_InBound\";
        directoryInfo = new System.IO.DirectoryInfo(searchFilePath);
        //Get list of only text files
        fileList = directoryInfo.GetFiles("*.txt");
        //Get the file count
        fileCount = fileList.get_Length();
        //One by one get each file
        for (i = 0; i < fileCount; i++)
            file = fileList.GetValue(i);
            //.Net method returns System.String need to marshal it to AX str data type
            fromName = file.get_FullName();
            axFromName = fromName;
            //Display the name of the fetched file
            info(fromName);
            moveName = file.get_Name();
            axMoveName = moveName;
            //Move to archive folder
            moveFileName = @"\AX_Archive\" + axMoveName;
            file.MoveTo(moveFileName);
            info("File moved to " + moveFileName);
    catch(Exception::CLRError)
        e = ClrInterOp::getLastException();
        while (e)
            error(e.get_Message());
            e = e.get_InnerException();
    catch
        error("An unknown exception has occurred");
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
Dynamics AX Sustained Engineering: Unable to Browse List Pages in EP when running SharePoint 2010 with Windows Server 2008 R2 (64 Bit) Blog bot DAX Blogs 0 29.12.2010 02:16
paruvella: Issues with EP tools, on 64-bit Windows server 2008. Blog bot DAX Blogs 0 03.12.2010 19:11
Microsoft Dynamics CRM Team Blog: Building a Self-Contained Virtual CRM Development Server Blog bot Dynamics CRM: Blogs 0 05.05.2009 10:05
Microsoft Dynamics CRM Team Blog: 32-bit vs. 64-bit CRM SDK Assemblies Blog bot Dynamics CRM: Blogs 0 11.09.2008 20:05
Часовой пояс GMT +3, время: 14:59.
