Старый 21.02.2012, 11:28   #3
2rik is offline
2rik
Спасибо. Сам не понимаю, почему он может не подхватывать.
Ниже привожу код плагина
using System;
using System.ServiceModel;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Microsoft.Xrm.Sdk;
using Microsoft.Xrm.Client;
using Microsoft.Xrm.Sdk.Query;
using System.Collections;
using Microsoft.Xrm.Sdk.Client;
using System.Data;
namespace WorkWithProject
    public  class Plugin : IPlugin
        public  OrganizationServiceContext orgContext;
        public  OrganizationServiceProxy _serviceProxy;
        public  IOrganizationService _service;
        public  int Nomer = 0;
        public string ProjectPrefix = "";
        public  string StrNomer = "";
        public  string EntityPrefix = "";
        public  void Init()
            _serviceProxy.EnableProxyTypes();
            _service = (IOrganizationService)_serviceProxy;
            // Create the OrganizationServiceContext object that will generate the IQueryable collections for LINQ calls.
            orgContext = new OrganizationServiceContext(_service);
        public  string WorkWithNumber(int Number, string EntityPrefix, string PrefixProekta)
            string result = null;
            result = String.Format("{1}{2}-{0,5:00000}", Number, EntityPrefix, PrefixProekta);
            return result;
        public  void Execute(IServiceProvider serviceProvider)
            IPluginExecutionContext context = (IPluginExecutionContext)serviceProvider.GetService(typeof(IPluginExecutionContext));
            IOrganizationServiceFactory serviceFactory = (IOrganizationServiceFactory)serviceProvider.GetService(typeof(IOrganizationServiceFactory));
            _service = serviceFactory.CreateOrganizationService(context.UserId);
            ITracingService trace = (ITracingService)serviceProvider.GetService(typeof(ITracingService));
            if (context.Depth > 1)
                return;
            Entity entity = null;
            if (context.InputParameters.Contains("Target") && context.InputParameters["Target"] is Entity)
                // Obtain the target business entity from the input parmameters.
                entity = (Entity)context.InputParameters["Target"];
                // TODO Test for an entity type and message supported by your plug-in.
            else return;
            if (entity != null)
                try
                    Guid EntityId = ((Guid)entity.Id);
                    if (entity.LogicalName == "project_task")
                        #region
                        //вынимаем задачу проекта-------------------------------------------------------------
                        var ProjectTask = (from PT in orgContext.CreateQuery<project_task>()
                                           where (PT.Id == EntityId)
                                           select new project_task{ Id = PT.Id }).FirstOrDefault();
                        if (ProjectTask == null) return;
                        if (ProjectTask.project== null) return;
                        else
                            //вытягиваем проект-------------------------------------------------------
                            var Project = (from P in orgContext.CreateQuery<project>()
                                           where (P.Id == ProjectTask.project.Id)
                                           select new project{ Id = P.Id }).FirstOrDefault();
                            if (Project == null) return;
                            if (Project.number== null) Nomer = 1;
                            else Nomer = (int)Project.task_number;
                            EntityPrefix = "T";
                            if (Project.prefix != null) ProjectPrefix = Project.prefix;
                            StrNomer = WorkWithNumber(Nomer, EntityPrefix, ProjectPrefix);
                            ProjectTask.number = StrNomer;
                            orgContext.UpdateObject(ProjectTask);
                            _service.Update(ProjectTask);
                            Project.number = Nomer + 1;
                            orgContext.UpdateObject(Project);
                            _service.Update(Project);
                            //orgContext.SaveChanges();
                    else if (entity.LogicalName == "out_task")
                        #region
                        var ProjectTaskOut = (from PTO in orgContext.CreateQuery<out_task>()
                                              where (PTO.Id == EntityId)
                                              select new out_task{ Id = PTO.Id }).FirstOrDefault();
                        if (ProjectTaskOut == null) return;
                        if (ProjectTaskOut.project== null) return;
                        else
                                           where (P.Id == ProjectTaskOut.project.Id)
                            if (Project.out_task_number == null) Nomer = 1;
                            else Nomer = (int)Project.out_task_number;
                            EntityPrefix = "E";
                            ProjectTaskOut.number = StrNomer;
                            orgContext.UpdateObject(ProjectTaskOut);
                            _service.Update(ProjectTaskOut);
                            Project.out_task_number = Nomer + 1;
                        #endregion
                    else if (entity.LogicalName == "defect")
                        #region
                        var Defect = (from D in orgContext.CreateQuery<defect>()
                                      where (D.Id == EntityId)
                                      select new defect{ Id = D.Id }).FirstOrDefault();
                        if (Defect == null) return;
                        if (Defect.project== null) return;
                        else
                                           where (P.Id == Defect.project.Id)
                            if (Project.new_nomer_defecta == null) Nomer = 1;
                            else Nomer = (int)Project.new_nomer_defecta;
                            EntityPrefix = "D";
                            if (Project.prefix!= null) ProjectPrefix = Project.new_prefix_numeracii;
                            Defect.number= StrNomer;
                            orgContext.UpdateObject(Defect);
                            _service.Update(Defect);
                            Project.number= Nomer + 1;
                        #endregion
                    else if (entity.LogicalName == "changes")
                        #region
                        var Izm = (from I in orgContext.CreateQuery<changes>()
                                   where (I.Id == EntityId)
                                   select new changes{ Id = I.Id }).FirstOrDefault();
                        if (Izm == null) return;
                        if (Izm.new_proekt == null) return;
                        else
                                           where (P.Id == Izm.project.Id)
                            if (Project.changes== null) Nomer = 1;
                            else Nomer = (int)Project.number;
                            EntityPrefix = "C";
                            Izm.new_nomer = StrNomer;
                            orgContext.UpdateObject(Izm);
                            _service.Update(Izm);
                            Project.new_nomer_izmeneniya = Nomer + 1;
                        #endregion
                    else if (entity.LogicalName == "risk")
                        #region
                        var Risk = (from R in orgContext.CreateQuery<risk>()
                                    where (R.Id == EntityId)
                                    select new risk{ Id = R.Id }).FirstOrDefault();
                        if (Risk == null) return;
                        if (Risk.project== null) return;
                        else
                                           where (P.Id == Risk.new_proektid.Id)
                            EntityPrefix = "R";
                            if (Project.prefix!= null) ProjectPrefix = Project.prefix;
                            Risk.number= StrNomer;
                            orgContext.UpdateObject(Risk);
                            _service.Update(Risk);
                        #endregion
                catch (FaultException<OrganizationServiceFault> ex)
                    throw new InvalidPluginExecutionException(ex.Message,ex);
Последний раз редактировалось 2rik; 21.02.2012 в 11:43.
Создание Order из другой сущности ashuron Dynamics CRM: Разработка 3 16.11.2011 22:21
создание прайса бизнес-процессом lin2nil Dynamics CRM: Функционал 2 12.10.2011 00:06
Как открыть в новом окне созданный бизнес-процессом объект? NatK Dynamics CRM: Разработка 6 30.09.2009 09:18
Создание экземпляра кастомной сущности из плагина Roman08 Dynamics CRM: Разработка 14 31.08.2009 21:34
Создание объекта сущности из другого объекта! SnSS Dynamics CRM: Разработка 5 29.05.2008 13:38
Часовой пояс GMT +3, время: 10:11.
