Старый 04.02.2013, 16:23   #1
plumbum is offline
plumbum
182 / 86 (3) ++++
DataMembers для DataContract автоматически
Вот набросал простой скрипт, создающий методы аннотированные [DataMemberAttribute] для всех переменных класса:
static void GenerateDataMembers(Args _args)
    #define.classDeclaration('classDeclaration')
    str strAttributeMethodLine1 = '[DataMemberAttribute]\n';
    str strAttributeMethodLine2 = 'public %1 parm%2(%1 _%2 = %2)\n';
    str strAttributeMethodLine3 = '{\n';
    str strAttributeMethodLine4 = '\t%2 = _%2;\n';
    str strAttributeMethodline5 = '\treturn %2;\n';
    str strAttributeMethodLine6 = '}';
    str strAttributeMethod      = strAttributeMethodLine1 +
                                  strAttributeMethodLine2 +
                                  strAttributeMethodLine3 +
                                  strAttributeMethodLine4 +
                                  strAttributeMethodLine5 +
                                  strAttributeMethodLine6;
    str                         lstrAttributeMethodSource;
    ClassId                     lclsClassId             = classNum(<MyClassName>); //change this paramter
    SysDictClass                lclsDictclass           = new SysDictClass(lclsClassId);
    ClassBuild                  lclsClassBuild          = new ClassBuild(lclsDictclass.name(), true);
    Set                         lsetMethods             = lclsDictClass.methods(true, false, false);
    SetEnumerator               lsenMethods             = lsetMethods.getEnumerator();
    Map                         lmapMethods             = new Map(Types::String, Types::Class);
    MapEnumerator               lmenMethods;
    SysDictMethod               lclsMethod;
    str                         lstrClassDeclaration    = lclsDictclass
                                                          ? TreeNode::findNode(strFmt('\\Classes\\%1\\classDeclaration', lclsDictclass.name())).AOTgetSource()
    Map                         lmapMemberVariableParm  = new Map(Types::String, Types::String);
    str                         lstrMemberVarPare;
    str                         lstrMemberVarType;
    str                         lstrMemberVarName;
    str                         lstrMemberVarMName;
    str                         lstrMemberVarPrefName;
    int                         lintStrLen,
                                lintMemberVarStartPos,
                                lintMemberVarEndPos;
    container                   lconMemberVars;
    int                         lintConLen, i;
    if (!lstrClassDeclaration)
        return;
    while (lsenMethods.moveNext())
        lclsMethod = lsenMethods.current();
        lmapMethods.insert(lclsMethod.name(), lclsMethod);
    lintStrLen                  = strLen(lstrClassDeclaration);
    lintMemberVarStartPos       = strFind(lstrClassDeclaration, '{' ,1, lintStrLen);
    lintMemberVarEndPos         = strFind(lstrClassDeclaration, '}',1, lintStrLen);
    lstrClassDeclaration        = subStr(
                                    lintMemberVarStartPos+1,
                                    lintMemberVarEndPos - lintMemberVarStartPos - 1);
    lstrClassDeclaration        = strReplace(lstrClassDeclaration, '\n', '');
    lstrClassDeclaration        = strReplace(lstrClassDeclaration, '\t', '');
    lstrClassDeclaration        = strReplace(lstrClassDeclaration, ';', ',');
    lstrClassDeclaration        = subStr(lstrClassDeclaration, 1, strLen(lstrClassDeclaration) - 1);
    lconMemberVars              = str2con(lstrClassDeclaration);
    lintConLen                  = conLen(lconMemberVars);
    for (i = 1; i <= lintConLen; i++)
        lstrMemberVarPare       = conPeek(lconMemberVars, i);
        lstrMemberVarPare       = strLRTrim(lstrMemberVarPare);
        lstrMemberVarType       = subStr(lstrMemberVarPare, 1, strFind(lstrMemberVarPare, ' ', 1, strLen(lstrMemberVarPare))-1);
        lstrMemberVarName      = strLTrim(subStr(lstrMemberVarPare, strLen(lstrMemberVarType) +1 , strLen(lstrMemberVarPare) - strLen(lstrMemberVarType)));
        if (! lmapMethods.exists('parm'+lstrMemberVarName))
            lstrAttributeMethodSource = strFmt(strAttributeMethod, lstrMemberVarType, lstrMemberVarName);
            lclsClassBuild.addMethod('parm' + lstrMemberVarName, lstrAttributeMethodSource);
    lclsClassBuild.classNode().AOTcompile();
уже существующие методы пересоздаваться не будут.
P.S.
а то уже совсем надоело все это "руками" делать.
Надеюсь еще кому-то пригодиться
http://www.axdevposts.blogspot.com
Пришел, уведел.... отойди, дай другому увидеть!
За это сообщение автора поблагодарили: mazzy (2), trud (1), Logger (1), gl00mie (2).
Старый 04.02.2013, 16:55   #2
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
1. So drop the Hungarian
2.
System.Text.RegularExpression.Regex::replace(@'^.*\{(.*)\}.*$','$1')
За это сообщение автора поблагодарили: mazzy (2), gl00mie (2).
Старый 04.02.2013, 17:43   #3
plumbum is offline
plumbum
182 / 86 (3) ++++
1. Ну это такие требования у нас на проекте - я их тоже не любил, но ИМХО при автоподстановке в AX2012 очень удобно
2. А это Вы к чему? Я собственно собирался середину выудить, там мне заменять только потом надо было.
Старый 05.02.2013, 09:50   #4
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
1. Приношу свои соболезнования
2. Это и есть выудить середину - только короче
Старый 05.02.2013, 09:56   #5
gl00mie is offline
gl00mie
3,684 / 5803 (201) ++++++++++
Сообщение от plumbum Посмотреть сообщение
2. А это Вы к чему?
Это, наверно, к тому, что при наличии строк вида
    MyType   myVar;
можно сгенерить код соотв. методов с помощью регулярных выражений, заменив
Код:
^\s*(\w+)\s+(\w+);.*
на
Код:
[DataMemberAttribute]\npublic $1 parm\u$2($1 _$2 = $2)\n{\n    $2 = _$2;\n    return $2;\n}
За это сообщение автора поблагодарили: plumbum (1).
Старый 05.02.2013, 10:25   #6
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Не - тут просто заменой не обойтись - надо же еще удалить чего-то там. Я бы просто прошелся по матчам этого регекспа и сформировал код методов при помощи
strFmt(@'
%1 parm%2(%1 _value=%3)
      %3 = _value;
      return %3;
',  type, upperCaseName, lowerCaseName);
Старый 05.02.2013, 19:04   #7
plumbum is offline
plumbum
182 / 86 (3) ++++
Понял насчет регулярных выражений, не обратил внимание на то, что под $* имелись в виду параметры - извиняюсь.
В дополнение еще, конечно, надо было бы вставить код, выуживающий комментарии и макросы из classDeclaration. Ну что ж, в следующем релизе
Собственно код метода и формируется с помощью strFmt.
Старый 06.02.2013, 09:58   #8
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Если взять ScannerClass то комментарии макросы и прочее оно учтёт само.
Поит был не в strFmt а в использовании многострочных строк и в матчах регекспов
Старый 06.02.2013, 17:31   #9
Evgeniy2020 is offline
Evgeniy2020
309 / 68 (3) ++++
в приведенной ссылке
на сайте http://erpkb.com/Axapta/Klass/ScannerClass указана ссылка
http://erpkb.com/Axapta/Klass/ParserClass?v=1cfk а в ней ссылка (Перед чтением этой статьи рекомендуется изучить БНФ грамматику X++ )
http://msdn.microsoft.com/library/en...X++grammar.asp
ссылка не рабочая... можете указать рабочую ссылку на msdn?
Последний раз редактировалось Evgeniy2020; 06.02.2013 в 17:34.
Старый 06.02.2013, 19:11   #10
gl00mie is offline
gl00mie
Сообщение от Evgeniy2020 Посмотреть сообщение
в приведенной ссылке на сайте http://erpkb.com/Axapta/Klass/ScannerClass указана ссылка [...]ссылка не рабочая... можете указать рабочую ссылку на msdn?
Рабочую ссылку на msdn можно найти тут:
Старый 06.02.2013, 21:07   #11
Evgeniy2020
309 / 68 (3) ++++
http://msdn.microsoft.com/en-us/library/dd261486.aspx
спасибо но эта ссылка имнно то шо искал
Старый 06.02.2013, 23:19   #12
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Кстати, code upgrade tool содержит в себе парзер X++ на C#
ax2012, datamemberattribute, sysoperation framework
Автоматически пересчет цен/скидок в заказах Starling DAX: Функционал 2 11.04.2009 15:37
MAP автоматически George Nordic DAX: Программирование 2 05.07.2004 16:49
как автоматически выполнить код при импорте? puz DAX: Программирование 4 01.10.2003 10:54
Как автоматически заполнить поле InventDimId в таблице PriceDiscTable при импорте? Mike12345 DAX: Функционал 6 06.08.2003 11:29
AOS - не стартует автоматически при перезапуске системы Irvine DAX: Администрирование 7 28.07.2003 17:58
Часовой пояс GMT +3, время: 14:41.
