#4 |
Сообщение от Blog bot
First off, it's important to recognize that AX is single threaded in nature.
... The fastest compile is typically achieved by creating a "1-box" setup: SQL, AOS and Client on the same machine. ... The main limitation to incur on SQL is how much memory it uses. If the box has 16GB memory, allowing for 4GB SQL memory looks like a good setting. ... Jakob on behalf of the X++ compiler team. Но рекомендация предельно странная. Особенно для продуктива. |
