Старый 04.07.2013, 08:11   #1
25,554 / 848 (80) +++++++
Dynamics AX Sustained Engineering: Update conflict error thrown when an Intercompany Purchase Order is invoiced
Источник: http://blogs.technet.com/b/dynamicsa...-invoiced.aspx
ISSUE: When an Intercompany Purchase Order is invoiced, “Cannot edit a record in Purchase order lines (PurchLine). An update conflict occurred due to another user process deleting the record or changing one or more fields in the record.” error thrown.
RECOMMENDATION: In \DataDictionary\Tables\CustInvoiceJour\Methods\interCompanyUpdate, reread method should be called first to make sure that PurchLine table buffer uses its latest versionId
while select forupdate purchLine
where purchLine.PurchId == interCompanyPurchId
&& !purchLine.IsDeleted
purchLine.reread();
if
(inventTransIdMap.exists(purchLine.InventTransId))
purchLine.PurchReceivedNow =
inventTransIdMap.lookup(purchLine.InventTransId);
Similar function used in \Classes\SysCodeProfilerCleanUp\delete.
Dynamics AX Sustained Engineering: Announcing Cumulative Update 6 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 28.06.2013 21:12
Cumulative Update 1 for Microsoft Dynamics AX 2012 R2 Vadik DAX: База знаний и проекты 2 02.03.2013 10:14
Dynamics AX Sustained Engineering: Dynamics AX Compatibility with SQL Server 2008 Blog bot DAX Blogs 1 02.11.2012 00:11
Dynamics AX Sustained Engineering: POS Transaction with Sales Order that nets to $0.00 posting failure in statement Blog bot DAX Blogs 0 06.01.2011 20:16
DynamicsAxSCM: Sales and purchase prices in relation to the item price setup in Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 11.02.2010 09:05
Часовой пояс GMT +3, время: 21:46.
