Старый 17.01.2014, 00:15   #1
How to set properties for the Reference Group form control from code
Источник: http://alexvoy.blogspot.com/2014/01/...reference.html
<div dir="ltr" style="text-align: left;" trbidi="on">There is a small issue in AX 2012 with getting access to the siblings' properties of Reference Group form control - they are unavailable in AOT.
However, you still can get access to it from code during run time.
Let's say you have placed on your form a field named FilterCategory, which is a reference group, and you want to set its sibling FilterCategory_Name width to Column width value. As you can see there is no way to do that in AOT.
So you just create a method supposed to be called in the form init():
void setColumnWidthForFilterCategory()
int i;
Object childControl;
for (i = 1; i
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Часовой пояс GMT +3, время: 05:08.
