Старый 11.02.2014, 22:11   #1
emeadaxsupport: AX Retail: Enabling reliable session support in POS – RealTimeServices in AX 2012 R2
Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r2.aspx
Description:
We have
received some feedback from customers that inconsistence occurs when the
network connect fails during a RealTimeService operation from the POS. To
ensure that POS calls to RealTimeService is working reliable, we can enable the
reliable session in the config files. After enabling this feature, the communication
will ensure consistency in the calls.
NB: Enabling this feature might slightly decrease the performance.
Solution:
When you want to edit the Web.Config or POS.Exe.Config file it is a very good practice to
use the SvcConfigEditor.exe, which comes with the Microsoft SDK. With this tool it is very easy to see the possible values in the
different options and it provides you a good overview what is running as a service and what is running on the client.
To get the reliable session to work we have to change certain values.
  1. The MaxBufferSize andMaxReceivedMessageSize needs to be the same value.
  • maxBufferSize="10485760"
  • maxReceivedMessageSize="10485760"
2. The values needs to be changed.
  • reliableSession ordered="true"
  • transactionFlow="true"
  • transferMode="Buffered"
Example files: Content might have to be adjusted.
POS.EXE.CONFIG file
WEB.CONFIG FILE
NB. The next release of AX (Dynamics AX 2012 R3)
has reliable session enabled by default.
Author: Kim Truelsen
Date: 11/2-2014
emeadaxsupport: Country specific update to support SEPA export formats for remittance journal in Promissory Notes and Bill of Exchange in Microsoft Dynamics AX 2012 R2 is available Blog bot DAX Blogs 0 04.02.2014 22:11
emeadaxsupport: AX for Retail 2012 R2: Password maintenance in the POS Blog bot DAX Blogs 0 18.01.2014 02:26
emeadaxsupport: AX for Retail 2012 R2: Using Multiple Blank Operations and Triggers Blog bot DAX Blogs 0 28.09.2013 23:12
emeadaxsupport: AX for Retail 2012: New steps when applying a POS hotfix Blog bot DAX Blogs 0 06.03.2013 22:13
emeadaxsupport: Preliminary Microsoft Dynamics AX 2012 R2 content now on TechNet and MSDN! Blog bot DAX Blogs 0 10.11.2012 08:20
Часовой пояс GMT +3, время: 21:12.
