Старый 15.05.2014, 19:11   #1
25,643 / 848 (80) +++++++
bojensen: How to find All USR Layer Elements in AOT
Источник: http://blogs.bojensen.eu/?p=4886
How to Find all the elements which in present in USR layer To find all USR layer elements in AOT , you can write job with following code, when you will run this job it will create a new project named “TheAxapta_UsrObject”. In this Project you find all elements which is present in USR layer…
Read more →
How to find your object in AOT projects Blog bot DAX Blogs 0 03.05.2011 06:15
Dynamics AX FAQ: How to find an AOT object by its property? Blog bot DAX Blogs 2 07.11.2008 12:54
Dynamics AX FAQ: How to get the top most application layer of an AOT object? Blog bot DAX Blogs 0 19.10.2008 18:05
axStart: How to find line of code with a question mark in your AOT. Blog bot DAX Blogs 0 16.04.2008 22:05
daxmy: AOT Find function Blog bot DAX Blogs 0 17.08.2007 01:23
Часовой пояс GMT +3, время: 14:57.
