Старый 31.07.2014, 15:36   #4
ax_mct is offline
ax_mct
2,548 / 1091 (0) ++++++++
Announcing Compatibility Certification of Safari 5.1.2 with Dynamics AX 2012
http://blogs.technet.com/b/dynamicsa...s-ax-2012.aspx
Dynamics AX Sustained Engineering is proud to announce the following compatibility:
Product
Dynamics AX Version
Apple Safari 5.1.2 on Windows and Mac OS
Dynamics AX 2012
To use the Safari browser, you must install Microsoft Dynamics AX hotfix 2686124. Enterprise Portal supports Safari only for end user tasks in the portal. Enterprise Portal does not support Safari for developer or system administrator tasks.
The System requirements of Dynamics AX 2012 is in the process of being updated on Customer Source and Partner Source.
Windows 8.1/IE11
http://blogs.technet.com/b/dynamicsa...-and-ie11.aspx
We are happy to announce the support of AX 2012 and AX 2012 R2 on Windows 8.1/IE11. To use Internet Explorer 11.0, you must install the hotfixes listed in Knowledge Base article 2958723
Даже с AX 2012 не каждый новый браузер сразу поддерживается.
За это сообщение автора поблагодарили: Harry (1).
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Enterprise Portal Screencasts at Channel9.msdn.com Blog bot DAX Blogs 6 01.07.2008 19:38
jinx: Microsoft Dynamics AX 2009 Enterprise Portal Entwicklung Samples Blog bot DAX auf Deutsch 0 27.06.2008 04:06
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 1 Blog bot DAX Blogs 0 26.06.2008 09:05
Часовой пояс GMT +3, время: 01:56.
