Старый 20.11.2014, 11:11   #1
25,626 / 848 (80) +++++++
emeadaxsupport: Cumulative Update 8 for Microsoft Dynamics AX 2012 R3 now available!
Источник: http://blogs.msdn.com/b/axsupport/ar...available.aspx
Cumulative Update 8 (CU8) for Microsoft Dynamics AX 2012 R3 is now available on CustomerSource and PartnerSource. CU8 includes many new features, as well as regulatory updates and hotfixes, so check it out!
What’s included in CU8
CU8 for AX 2012 R3 includes:
How to install CU8
To get started with your installation of CU8, complete these steps:
  1. Review the System Requirements to make sure that your environment supports CU8.
  2. Download CU8 from the Hotfix Download Available section on the CU8 download page.
  3. Install CU8 by following the step-by-step instructions in the Installation Guide for Microsoft Dynamics AX 2012 R3 Cumulative Update 8.
To help you better understand the CU8 installation, you may also want to see the following
videos:
Help and how-to content
Product documentation for AX 2012 (including all versions and cumulative updates) is available on TechNet.
For more information about all versions of AX 2012, see the following resources:
Known issues
The known issues in CU8 can be found by using the Issue search tool in Lifecycle Services. You can log in to Lifecycle Services using your CustomerSource or PartnerSource account, and then in the Issue search box, enter CU8 Known issues.
Старый 20.11.2014, 11:36   #2
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1849 (69) ++++++++
Звон бокалов, брызги шампанского..
-ТСЯ или -ТЬСЯ ?
Старый 21.11.2014, 02:17   #3
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,311 / 3547 (125) ++++++++++
А где-нибудь говорится о том, откуда качать автономный установщик? Ну... кроме как абстрактной ссылки на LifeCycle Services?
Я вот такую ссылку нарыл: https://update.lcs.dynamics.com/Download/Index/ Cumulative update 8 slipstream
Старый 21.11.2014, 07:29   #4
Vadik is offline
Vadik
Аватар для Vadik
https://mbs2.microsoft.com/Knowledge...;EN-US;2998197
-ТСЯ или -ТЬСЯ ?
Старый 21.11.2014, 08:18   #5
AndyD is offline
AndyD
2,560 / 2479 (88) +++++++++
Там ссылка на AxUpdate, который при запуске обращается к LCS для закачки обновлений.
Этот обновлятор можно напрямую из LCS получить
Кстати, номер KB непосредственно CU8
KB3016389 Microsoft Dynamics AX 2012 R3 CU8
Но по этому номеру напрямую ничего скачать не удается
Axapta v.3.0 sp5 kr2
Старый 24.11.2014, 17:06   #6
не совсем верно
KB 3016389 имеет не совсем верное LCS описание, указывая что это основной CU8, на самом деле кейс трекает лишь изменение номера билдов при аплайе. Однако 3016389 и 2998197 взаимозависимы и исключение одного из них влечет отключение другого
ax2012r3
emeadaxsupport: Cumulative SEPA credit transfer and SEPA direct debit update for Austria direct debit specific country format and update COR1 mandate scheme in Microsoft Dynamics AX 2012 R2 has been released Blog bot DAX Blogs 1 16.12.2013 18:16
Dynamics AX Sustained Engineering: Announcing Cumulative Update 7 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 15.12.2013 02:18
emeadaxsupport: Unexpected Compiler Errors installing Cumulative Update 7 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 07.11.2013 06:11
emeadaxsupport: New and updated content is available for cumulative update 6 for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 27.06.2013 19:11
Часовой пояс GMT +3, время: 18:02.
