Старый 18.05.2004, 09:24   #3
agri is offline
agri
Я делал так правда из БЭСТа с 1С можно провести аналогию
// Constructor of PurchTable Line Document return document ref
Private PurchId constructPurchTable( Nnoper Nnoper,
Nndoc Nndoc,
Dataoper Dataoper,
Best_Schet Dt_schet,
Best_code Dt_code,
Best_Schet Kt_schet,
Best_code Kt_code,
Nameoper Nameoper,
Summa Summa,
Valuta Valuta,
User_date User_date,
User_code User_code)
// Declare
PurchTable purchTable;
PurchLine purchLine;
NumberSeq numberSeq;
BestLineType bestLineType;
VendTable vendTable;
Best_code Vendor;
TTSBegin;
purchTable.clear();
purchTable.PurchaseType = PurchaseType::Purch;
numberSeq = NumberSeq::newGetNum(PurchParameters::numRefPurchId());
purchTable.PurchId = numberSeq.num();
purchTable.initValue();
if (Dt_code)
Vendor = Dt_code;
else
Vendor = Kt_code;
// find vend account
select
AccountNum
from VendTable
Where VendTable.AccountNum == Vendor;
if(!VendTable.AccountNum)
VendTable.clear();
VendTable.AccountNum = Vendor;
VendTable.NameAlias = "Íåèçâåñíûé Âåíäîð èç ÁÝÑÒÀ";
VendTable.Name = "Íåèçâåñíûé Âåíäîð èç ÁÝÑÒÀ";
VendTable.VendGroup = 'Òîâ';
VendTable.Currency = 'RUR';
VendTable.LanguageId = 'RU';
VendTable.PriceCurrency = 'RUR';
if(VendTable.validateWrite())
VendTable.insert();
purchTable.OrderAccount = Vendor;
purchTable.InvoiceAccount = Vendor;
purchTable.CurrencyCode = "RUR";
purchTable.VendGroup = "Òîâ";
purchTable.LanguageId = "ru";
purchTable.InventLocationId = "ÎÑÍ";
purchTable.ItemBuyerGroupId = "Ïðîäóêòû";
purchTable.PurchPoolId = "ÎñíÇàê";
purchTable.transferOrderAccountAuto();
bestLineType = this.getLineType(Dt_schet,Kt_schet);
purchTable.InclTax = NoYes::Yes;
purchTable.TaxGroup = "ÍÄÑ/-";
if (purchTable.validateWrite())
purchTable.insert();
// Create line
purchLine.clear();
purchLine.initFromPurchTable(purchTable);
purchLine.PurchId = purchTable.PurchId;
purchLine.ItemId = "111";
purchLine.PriceUnit = 1;
purchLine.PurchPrice = Summa;
purchLine.LineAmount = Summa;
purchLine.CurrencyCode = "RUR";
purchLine.PurchQty = 1;
purchLine.PurchUnit = "ØÒ";
purchLine.TaxItemGroup = "Ò20/-";
purchLine.PurchaseType = purchTable.PurchaseType;
purchLine.VendAccount = purchTable.OrderAccount;
purchLine.VendGroup = purchTable.VendGroup;
purchLine.Name = Nameoper;
purchLine.initValue();
if (purchLine.validateWrite())
purchLine.insert();
TTSCommit;
Return purchTable.PurchId;
Программное создание новых записей Владимир Максимов DAX: Программирование 35 06.03.2006 14:08
Создание закупки на основе контракта. NJD DAX: Программирование 0 06.09.2004 13:01
Программное создание закупки agri DAX: Программирование 3 13.05.2004 16:41
Номер возврата в форме Создание закупки OlegKocherga DAX: Функционал 5 12.03.2004 12:12
Создание Закупки по Заказу для другой Компании Anton Sk. DAX: Функционал 3 19.12.2001 23:42
Часовой пояс GMT +3, время: 20:04.
