Старый 03.12.2016, 01:11   #1
25,644 / 848 (80) +++++++
organicax: Stop conditions Workflow line manager = 2
Источник: https://organicax.com/2016/12/02/sto...ine-manager-2/
In a previous post we had a look at the stop condition where the line manager is = 1. If you want two levels of approval then one option you have is to use line manager = 2. This will allow you to have two levels based on the condition set on the hierarchy options Assign to all users retrieved.
Here is a quick overview.
AX2012 CU11
Cheers
Lachlan
Filed under: Workflow
Старый 03.12.2016, 01:11   #2
organicax: Stop conditions Workflow line manager = 1
Источник: https://organicax.com/2016/12/02/sto...ine-manager-1/
If you are setting up workflow and using the managerial hierarchy then you will have to play with the stop conditions as the rules for what person is returned for approval. One of the stop conditions would be line manager = 1. This will stop at the manager one level up.
AX2012 CU11
Cheers
Lachlan
Nav developer: Table Information including Index information (Usage, Blocks and Reads) Blog bot Dynamics CRM: Blogs 0 25.08.2009 19:34
NAV Sustained Engineering Team Blog: Index Usage Query Blog bot Dynamics CRM: Blogs 0 26.02.2008 12:29
Часовой пояс GMT +3, время: 03:54.
