#2 |
Пост похоже остался незамеченным, а там интересное:
This R3 feature is implemented in the kernel. The usage is not limited to reporting. Attached is a sample project showing how this kernel feature is used in case of multi-threading in Ax: each thread creates its own instance of a temp table, inserts rows into the table, and passes the table name back to the main thread (crossing session boundary), where contents from each temp table is then merged into one DB table using set-based insert. At the end, the code must despose the temp tables. The code is for demonstraction only. A more practical application to leverage this feature is in batch processing
-ТСЯ или -ТЬСЯ ? Последний раз редактировалось Vadik; 14.02.2017 в 14:42. |
| За это сообщение автора поблагодарили: fed (3), Logger (3). | |
| Теги |
| ax2012r3, srsreportdataproviderpreprocess, ssrs, thread, полезное, производительность |
