Старый 09.11.2018, 05:04   #1
crmtipoftheday: Tip #1188: The case of the missing activity tab
Источник: https://crmtipoftheday.com/1188/the-...-activity-tab/
I was recently upgrading a client from CRM 2011 to Dynamics 365 online, and for one custom entity, after reconfiguring the form and adding the timeline control, the form would only display the notes tab of the social pane.
I removed the pane from the form, saved, published, and re-added the pane, and all I could see was the notes tab.
Next, I tried saving the form as a new form, but my experience was the same. Whatever I tried I could only see the notes pane.
Wanting to avoid the draconian solution suggested in the Dynamics forums to recreate the entity, my next step was to try creating a new form–not save and new, but hit the new button to make a totally new form.
At first it looked like I was still stuck, because the new form still showed just the notes tab, but after removing the social pane from the form, saving and publishing, then adding the timeline control back to the new form, I now could see all of the tabs of the social pane.
Summary: If this happens to you, create a new form and add the timeline control to it.
(Facebook and Twitter cover photo by Russ Ward on Unsplash)
crmtipoftheday: Tip #1006: Case management vs. ticket management in Dynamics 365 Blog bot Dynamics CRM: Blogs 0 23.10.2017 19:12
Get Model element type name from its ID Blog bot DAX Blogs 0 14.02.2017 01:13
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 18:26.
