Старый 28.02.2019, 02:17   #13
ax_mct is offline
ax_mct
2,548 / 1091 (0) ++++++++
https://docs.microsoft.com/en-us/dyn...ed/one-version
Backward compatibility covers binary and functional compatibility. Binary compatibility means that you can apply an update on any runtime environment without needing to recompile, reconfigure, or redeploy customizations. This also means that on a development environment at design time, X++ public and protected APIs and metadata are not modified or deleted. If Microsoft needs to break compatibility by removing obsolete APIs, it will be communicated 12 months in advance and follow a deprecation schedule. Functional compatibility is about user experience, all new experiences will be opt-in.
Backward compatibility does not include non-X++/metadata APIs. Microsoft reserves the right to update versions of any dependencies the product uses, as well as remove dependencies without early warning. Microsoft does not commit to maintain backwards compatibility of dependent software libraries unless expressly stated.
Пока вижу что в части функциональной совместимости речь только про UX. Я так думаю что если приучить к Runtime ошибкам то здесь то там время от времени то UX не меняется
organicax: Building an aggregate data entity to access a measure via Odata Blog bot DAX Blogs 0 10.08.2017 20:11
atinkerersnotebook: Creating New Customer Notifications for Dynamics 365 for Operations using Flow and the Common Data Service Blog bot DAX Blogs 0 15.12.2016 22:12
stoneridgesoftware: Data Migration Observations for Microsoft Dynamics 365 for Operations (AX7) Blog bot DAX Blogs 0 10.12.2016 02:21
kurthatlevik: Master data concepts Blog bot DAX Blogs 0 18.02.2016 12:11
Часовой пояс GMT +3, время: 04:29.
