#1 |
crmtipoftheday: Tip #1303: Apps and Flows, buses and future access
Источник: https://crmtipoftheday.com/1303/apps...future-access/
============== You are writing canvas apps and Flows, but what happens if you get hit by a bus? How do you make sure that someone will be able to edit them in the future? Option 1: add them to a solution. If you create your Flow or canvas app in a solution, Flows and canvas apps are stored in the Common Data service, and they will be findable from the solution as well as the default solution for your environment. Option 2: if you can’t use a solution, create your App or Flow as a service account, and then share it with yourself as a co-owner. That way other administrators will be able to get to your app or flow if you aren’t there. Cover photo by Ricardo Esquivel from Pexels. Источник: https://crmtipoftheday.com/1303/apps...future-access/
| Тема | Ответов | |||
| crmtipoftheday: Tip #1140: Get ready for October 2018 release | 0 | |||
| crmtipoftheday: Tip #1094: It is Time to Go with the Flow | 0 | |||
