Старый 19.11.2019, 12:42   #1
SuperStar88 is offline
SuperStar88
? AX 2009. SysListPageHelper::handleInitPreSuper
На некоторых формах в Init() прописаны такие штуки, для чего они?
(Например, форма InventTable)
    SysListPageHelper::handleInitPreSuper(element);
    super();
    SysListPageHelper::handleInitPostSuper(element);
Старый 19.11.2019, 16:00   #2
dech is offline
dech
Аватар для dech
647 / 350 (13) ++++++
Сообщение от SuperStar88 Посмотреть сообщение
    super();
Как насчет заглянуть внутрь и посмотреть как оно работает? Там и с документацией тоже все норм вроде.
/// <summary>
/// Performs all necessary actions for preparing to open a task page from a list page that should be
/// taken during the <c>init</c> method before calling the <c>super</c> method.
/// </summary>
/// <param name="taskPageFormRun">
/// The <c>FormRun</c> instance that is being opened.
/// </param>
/// <remarks>
/// Call this method during the <c>Init</c> method of the form before the <c>super</c> method. This
/// method may clear the table record that is held in the <c>args.record</c> property.
/// </remarks>
public static void handleInitPreSuper(FormRun taskPageFormRun)
    if (taskPageFormRun == null)
        throw error(strfmt("@SYS115249", #taskPageFormRun));  // "The argument 'taskPageFormRun' cannot be null."
    if (taskPageFormRun.args() == null)
        throw error(strfmt("@SYS115334", #taskPageFormRun, #Value_Args));   // "The FormRun parameter '%1' cannot have a null args() value."
/// <summary>
/// taken in the <c>init</c> method after you call the <c>super</c> method.
/// </summary>
/// </param>
/// <remarks>
/// If the form has been opened by using the <c>FormOpenMode::ForEdit</c> parameter, the query,
/// including the user-defined filter, from the list page that opened this form will be copied and used
/// for this form. The selected record from that list page will be selected on this form. Any order-by
/// settings and the sort index will be cleared on the form and replaced with a new order-by based on
/// the <c>RecId</c> value.
/// </remarks>
public static void handleInitPostSuper(FormRun taskPageFormRun)
// no comments
Старый 19.11.2019, 17:42   #3
wojzeh is offline
wojzeh
Аватар для wojzeh
674 / 512 (19) +++++++
для выноса программной логики формы в отдельный класс.
грубо говоря, проще допилить такой класс, чем наворачивать спагетти непосредственно в форме.
ну, это в идеале.
Felix nihil admirari
stephenmann: Technical History of Dynamics AX - From Axapta 3.0 to AX2012 Blog bot DAX Blogs 5 03.03.2017 10:22
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
mbsturk: Ax 2009 Rollup 4 Version Checker Blog bot DAX Blogs 0 29.04.2010 17:05
Часовой пояс GMT +3, время: 12:02.
