Старый 21.04.2020, 11:11   #1
25,643 / 848 (80) +++++++
ariste.info: LCS DB API: automating Prod to Dev DB copies
Источник: https://ariste.info/en/2020/04/lcs-d...d-dev-db-copy/
The new LCS DB API endpoint to create a database export has been published! With it we now have a way of automating and scheduling a database refresh from your Dynamics 365 FnO production environment to a developer or Tier 1 VM. You can learn more about the LCS DB REST API reading these posts … Continue reading LCS DB API: automating Prod to Dev DB copies →
La entrada LCS DB API: automating Prod to Dev DB copies se publicó primero en ariste.info.
ariste.info: Get the T-SQL query from X++ Blog bot DAX Blogs 0 26.11.2019 11:11
ariste.info: Manually deploy Retail packages for Microsoft Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 07.10.2019 16:48
sertandev: Empowering D365 FO service endpoints with Azure API Management service Blog bot DAX Blogs 0 15.05.2019 22:11
Вылетает аxапта 4.0 при завершении работы Delfins DAX: Прочие вопросы 5 27.06.2007 15:43
Часовой пояс GMT +3, время: 16:55.
