Старый 22.02.2024, 21:13   #1
25,492 / 846 (79) +++++++
ariste.info: Azure Key Vault support in ISVLicenseGenerator v0.7
Источник: https://ariste.info/en/2024/02/isvli...ure-key-vault/
I’m once again back with a new version of the ISVLicenseGenerator tool, the piece of software I created with a modified version of the standard AXUtil.dll library that lets us sign license files using a cryptographic USB token. In the new version (v0.7) I’ve added the possibility of signing the license file using a certificate… Continue Reading Azure Key Vault support in ISVLicenseGenerator v0.7
ariste.info: Azure hosted build for Dynamics 365 Finance & SCM Blog bot DAX Blogs 0 01.05.2020 13:11
ariste.info: Calling the LCS Database Movement API in your Azure DevOps pipeline Blog bot DAX Blogs 0 28.01.2020 11:11
Часовой пояс GMT +3, время: 10:40.
