Старый 23.09.2004, 13:02   #8
simply2double is offline
simply2double
Аватар для simply2double
556 / 19 (2) ++
первый вариант был такой... так сказать SQL интуитивный:
insert_recordset tmp_Table (TransTableID,TransRecID)
select TransTableID,TransRecID
              from  MarkUpTrans
              join VendInvoiceTrans
              where MarkUpTrans
.TransRecId == VendInvoiceTrans .RecId &&
VendInvoiceTrans.InvoiceId == InvoiceId
но от этого ни чего не меняется...
а изменил прочитав во это:
Insert Recordset
Insert Recordset copies data from one or more tables directly into one resulting destination table - on a single server trip.
Syntax
     INSERT_RECORDSET <destination-table> ( <list-of-fields> )
        SELECT <list-of-fields1> FROM <source-table> [ WHERE <where-clause> ]
            [ JOIN <list-of-fields2> FROM <joined-source-table> [ WHERE <joined-where-clause> ]]
The <list-of-fields> in the destination table must match the list of fields in the source tables. Data is transferred in the order it appears in the list of fields. Fields in the destination table that are not present in the list of fields, are assigned zero-values as in other places in X++. System fields, including Recid, are assigned transparently by the kernel in the destination table.
method insert() when insert table from outside susenyudha DAX in English 1 29.08.2008 18:51
axaptapedia: Howto insert a menu reference into the MainMenu Blog bot DAX Blogs 0 03.08.2007 23:20
Про Insert, DoInsert и IAxaptaRecord::Insert murad DAX: Программирование 5 23.05.2006 12:26
Не найден исполнимый код метода insert Александр Костоусов DAX: Программирование 10 03.09.2004 16:47
Часовой пояс GMT +3, время: 09:56.
