Старый 26.11.2004, 11:48   #1
paucer is offline
paucer
? how to send an email?
i need to send an email from my Entrprise portal. How to do that? are there any examples in axapta?
thanks in advance
Старый 26.11.2004, 13:53   #3
Maxim Gorbunov is offline
Maxim Gorbunov
2,483 / 645 (26) +++++++
Re: how to send an email?
Изначально опубликовано paucer
А по какому событию?
Старый 26.11.2004, 14:27   #4
paucer is offline
paucer
Re: Re: how to send an email?
Изначально опубликовано Maxim Gorbunov
When real field value is modified in grid.
In this case i would put mail send code in datasorce's field's modified() method.
Старый 26.11.2004, 15:47   #5
max_woody_ru is offline
max_woody_ru
А можно ли как-нибудь проверить статус операции? Ни quickSend, ни sendMail ничего не возвращают... При неверных настройках почты просто выскакивает сообщение об ошибке. Хотелось бы его подавить и обрабатывать ситуацию вручную
Старый 26.11.2004, 16:29   #6
maxsmirnov is offline
maxsmirnov
экс-модератор
268 / 25 (1) +++
try/catch
убрать само сообщение - infolog.cut()
Старый 26.11.2004, 17:19   #7
paucer is offline
paucer
tips...
i downloaded Dndas Mailer Cotrol and activated SMTP service on my PC, but I get else branch in this pieace of code:
    sysMailer mailer = new SysMailer();
if (
mailer.validateAddress("my@address.com") == 6)
info("validation operation failed");
else
mailer.quickSend("our@address.com""my@address.com""subj""bod");
mailer.finalize();
let say that "my@address.com" is a valid addres. so i suspect, that my smtp servce produces an error.
maybe you have any tips how configure correct smpt or to test if my smtp works fine.
Paul...
Старый 26.11.2004, 17:31   #8
paucer is offline
paucer
my appologies, i wanted to write:
but I can't get in "else" branch in this pieace of code:
Старый 26.11.2004, 18:24   #9
Maxim Gorbunov
А DNS-сервер указывать пробовали.
IMPORTANT: If you do not specify a DNS server before calling this method then it will take a substantial amount of time to perform the validation. Make sure you use a DNS server!
и
ValidateAddress uses the DNSServers collections to perform mail exchange lookups, so it is highly recommended that you add multiple DNS servers to this collection. If no DNS servers have been added to the DNSServers collection then the following default servers will be tried in their respective order: "A.ROOT-SERVERS.NET", "B.ROOT-SERVERS.NET" and "C.ROOT-SERVERS.NET". If these servers are not available then the method call will fail and return an error code.
Dynamics Mobile: How to send a requestdocument without having a tasklet in a wizard Blog bot DAX Blogs 0 28.05.2008 16:05
Send alerts to online users in AX 4.0 Blog bot DAX Blogs 0 09.04.2008 00:05
Inside Dynamics AX 4.0: The Send Framework Blog bot DAX Blogs 0 05.10.2007 23:31
DynamicsTech: How to Setup Alerts in Dynamics Ax 4.0 Blog bot DAX Blogs 0 12.04.2007 11:50
how to receive pop3 email in Axapta ? Haroldas DAX: Программирование 8 01.11.2005 16:41
Часовой пояс GMT +3, время: 03:23.
