Старый 24.12.2002, 14:24   #5
kalex is offline
kalex
Действительно, оказалось ODBC виноват. И исправляется просто:
This error is due to an error in the Oracle ODBC driver, which return this error if the first returned row contains NULL values for some of the columns. This can in Axapta only occurs when you perform a outer join. The workaround for this bug is to set "PreFetch count" to 1 in the Oracle ODBC Driver configuration of the used Data Source Name. This setting has no performance implications since Axapta controls the array fetch by itself. -
axStart: How to convert a column in a table to a different type with the same name without losing data. Blog bot DAX Blogs 0 01.02.2008 21:21
jerry-dynamics: Where can you drag and drop an extended data type to? Blog bot DAX Blogs 0 16.06.2007 11:20
Ошибка SQL в модуле "Расчеты с персоналом" Карбофос DAX: Функционал 5 02.08.2002 12:44
Часовой пояс GMT +3, время: 12:42.
