Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 15.07.2005, 00:33   #6
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,348 / 3564 (125) ++++++++++
Say, my return procedure returns an integer:
Your procedure cannot return value (Transact-SQL ?).
Function can return value. If you use a function, I recommend to write:
        cmd.commandType(1);  //adCmdText, see ObjectBrowser in VBA
parameter "Parameter value";
cmd.CommandText(strfmt("SELECT spTestReturnRecordset '%1'"parameter));
as wrote Ace of Database, but do replace EXEC on SELECT
axaptabuilder: How to build Axapta application from XPO files stored in Visual Source Safe. Blog bot DAX Blogs 0 22.11.2006 15:20
Fred Shen: Convert Axapta date type value to datetime type value in SQL Server Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 10:48.
