Старый 27.01.2003, 12:03   #3
Wamr is offline
Wamr
1,737 / 868 (32) +++++++
Записей в блоге: 7
Цитирую technet
Creating "!=" relation on query
There's a whitepaper on queryexpressions.
You'll have to make range on T2.InventTransId and set the value to "(T1.InventTransId != T2.InventTransId)", assuming that you use T1 and T2 as datasourcenames in the query.
Dynamics AX: QueryRun and Query Objects - Binding operation failed to allocate buffer space Blog bot DAX Blogs 0 03.04.2009 08:05
palleagermark: Sample union query from AX 2009 Blog bot DAX Blogs 0 11.07.2008 20:05
Palle Agermark: List the datasources of a query object Blog bot DAX Blogs 0 28.10.2006 16:40
Dynamics AX Geek: Using query() Blog bot DAX Blogs 0 28.10.2006 16:40
Проблема с составлением Query axaLearner DAX: Программирование 10 01.12.2005 15:00
Часовой пояс GMT +3, время: 13:44.
