Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 22.03.2006, 12:04   #1
Maxim Gorbunov is offline
Maxim Gorbunov
2,483 / 646 (26) +++++++
query, compare two fields (by link)
Posted on 21-Mar-2006 at microsoft.public.axapta.programming by link
i want to make a query in the form ProdTable to show all the records that the
SchedEndDate > Delievry date.
how can i do?
You can specify not just simple range values but query conditions involving two or more fields using QueryBuildRange::value() method. Axapta kernel will parse these conditions into SQL statement automatically. For example, in your case:
Query       query;
query = new Query();
query.addDataSource(tableNum(ProdTable))
     .addRange(fieldNum(ProdTable, SchedEnd))
     .value(strfmt("(%1 > %2)",
                   fieldStr(ProdTable, SchedEnd),
                   fieldStr(ProdTable, DlvDate)));
info(query.dataSourceNo(1).toString()); // prints the resulting sql statement
Dynamics AX: QueryRun and Query Objects - Binding operation failed to allocate buffer space Blog bot DAX Blogs 0 03.04.2009 08:05
palleagermark: Sample union query from AX 2009 Blog bot DAX Blogs 0 11.07.2008 20:05
gatesasbait: On Dynamics Ax 5.0 compare tool enhancements Blog bot DAX Blogs 3 29.11.2007 13:42
Dynamics AX Geek: Using query() Blog bot DAX Blogs 0 28.10.2006 16:40
Проблема с составлением Query axaLearner DAX: Программирование 10 01.12.2005 15:00
Часовой пояс GMT +3, время: 08:26.
