Старый 19.05.2006, 12:35   #1
paucer is offline
paucer
Update problem in Enterprise Portal
Hello,
sometimes we experience such weird behaviour in EP:
when user updates one or more records in webform the record is being assigned wrong values : usually these values are from other record of the same table.
we can't catch whe and when it hapends, because it occurs very rarely.
It seems that bussiness connector acts incorrectly when updating.
Is it possible that some previously processed record 'sits' somewere in the cache and during update values from it are retrieved?
Is this because of curosrs used in Axapta? Maybe the cursor points to some old record and during kupdate sets values from that old record?
Is this business con. problem? Or should I look for problem in Axapta( e.g. in update procedures of the corresponding table)?
Maybe hot fix is availabel for bussiness. connector from microsoft?
thanx in advance
Paul
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Enterprise Portal Screencasts at Channel9.msdn.com Blog bot DAX Blogs 6 01.07.2008 19:38
jinx: Microsoft Dynamics AX 2009 Enterprise Portal Entwicklung Samples Blog bot DAX auf Deutsch 0 27.06.2008 04:06
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 1 Blog bot DAX Blogs 0 26.06.2008 09:05
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
Часовой пояс GMT +3, время: 00:07.
