Старый 25.08.2006, 00:40   #1
tangolp is offline
tangolp
web service
I'm using DAX 4.0. I'd like to know if it is possible to call a .Net web service from Axapta. If so, please provide sample code. Thank you!!
Старый 25.08.2006, 11:17   #2
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Afaik you can add reference to any assembly to the aot and use it as an ordinary ax class. So read .net docs for delais (maybe there is a better way, i don't know)
Consuming "CustomerService" Web Service Blog bot DAX Blogs 0 25.01.2008 15:10
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Axapta Lessons: Creating an IBF Compliant Web Service for Axapta Blog bot DAX Blogs 0 28.10.2006 18:22
Fred Shen: Consuming a Web Service in Dynamics AX 4 Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 20:48.
