Старый 28.10.2006, 18:14   #1
PatrickChua: Restore Axapta database
Источник: http://PatrickChuaAx.spaces.live.com...68AA!114.entry
Today I've tried to restore a backup of the current development environment to the laptop. Below is the procedures.
1.  Copy the entire application folder to your local appl folder
Ex: SP5CMBTEST
    Locate the source directory in bportal
   \bportal\axapta$\AX30SP5\APPL\ THEN CHOOSE THE version to copy
   ex.SP5CMDDEV
  \bportal\axapta$\AX30SP5\APPL\SP5CMBDEV
 COPY AND PASTE TO THE LOCAL DIRECTORY
 C:\Documents and settings\All Users\Application Data\Navision\Axapta Application
 Which can be found in the axapta configuration utility, system directory.
  1. Create a database in SQL Server SP5CMBTEST
A.      backup first the bportal
B.      locate this backup
C.      copy to local c:\devbak\SP5CMBTEST
D.      restore devbak\SP5CMBTEST to SQLSERVER in a new database named
      SP5CMDTEST
FORCE  RESTORE
  1. Restore the database to SP5CMBTEST
  1. Create a Log-In SP5CMBTEST, pls see how databases are configured properly
    1. goto sql enterprise manager
    2. goto security
    3. create a user SP5CMBTEST
    4. click databaseaccess tab, CLICK SP5CMBDEV, CLICK DB_OWNER
    5. CLICK MASTER, click public
    6. Click server roles tab
    7. Click all server role
    8. Click general tab
    9. Click Sql Server authentication
    10. Enter password   (bmssa)
    11. Verify Password (bmssa)
  1. Create a configuration, make sure it point to application, database, user as SP5CMBTEST
    1. Launch configuration file
    2. Choose the original configuration pointing to local directory
    3. Click manage configuration
    4. Click new configuration
    5. Type SP5CMBDEV
    6. CLICK SQL SERVER TAB
    7. Click database choose from dropdown list SP5CMBDEV
    8. Click database user id, TYPE SP5CMBDEV
    9. Click Database Password
    10. Click Use this password
    11. Enter bmssa in password
    12. Enter bmssa in confirm
    13. Click apply
    14. CLICK GENERAL TAB
    15. CLICK APPLICATION choose from dropdown SP5CMBDEV
    16. CLICK EXPORT
    17. LOCATE THE APPLICATION DIRECTORY IN DRIVE C , THIS WILL COPIED TO THE DIRECTORY
     IN C:\PROGRAM FILES\NAVISION\AXAPT CLIENTS\BIN
WHICH IS FOUND IN THE CONFIGURATION FILE GENERAL TAB  ALT.BIN DIRECTORY
  1. Create a shortcut pointing to SP5CMBTEST
           Locate the appl folder in local drive
           C:\documents and settings\all users\application data\navision\axapta
           application\appl\SP5CMBDEV
To verify if restore is complete
       Login in axapta, then look for latest data window with latest fields in form
      Examine also in aot  latest codes/classes, etc.
SysDictCoder: Axapta error handling and database transactions Blog bot DAX Blogs 0 28.10.2006 16:47
Axapta database archiving/purging gb DAX in English 2 17.07.2005 18:49
AX-05-020 Axapta Database MS-SQL MadLight DAX: Администрирование 9 12.01.2005 14:52
Часовой пояс GMT +3, время: 07:51.
