Старый 26.01.2007, 05:51   #1
Kashperuk Ivan: Adding Menu ReferencesMany developers often find...
Источник: http://kashperuk.blogspot.com/2006/1...evelopers.html
Many developers often find it very confusing when trying to add a menu reference into an existing menu.
The reference just doesn't want to be added. :)
And what confuses even more is that some of the menus are added normally, while others are not!
Let's look at an example:
"After creating of a new menu - menu1, I want to add 2 existing menus into it as references: Cust and Vend.
I right-click the menu1 node and select add->menu reference. Drag over the Cust menu (and everything goes fine), and then I try to drag over the Vend menu - and it DOESN'T work! I am lost. what can be the reason for this?"
The explanation is simple:
The menus that were expanded since the time you launched the client, can't be added as references.
You can experiment with this: Try opening the AX client and dragging over a menu as a menu reference. You can see that it works. Now, expand the menu in the AOT and try adding it as a menu reference again. You can see that it is impossible to add it any more. So, to avoid having problems when adding a menu as a reference, you should re-enter the Axapta client and, before expanding the menu, add the needed menu as a reference.
Original article:
http://erpkb.com/Axapta/OshibkaSozdanijaSsylkiNaMenju
Kashperuk Ivan: Another useful Editor Script for AX developers Blog bot DAX Blogs 9 10.11.2008 15:36
Kashperuk Ivan: Hotkeys and Find vs Filter in Dynamics AX 2009 Blog bot DAX Blogs 2 11.03.2008 12:06
Kashperuk Ivan: Find all reports with datasources innerjoined 1:n Blog bot DAX Blogs 2 09.03.2008 14:05
Kashperuk Ivan: 3 great Tabax Plugins Blog bot DAX Blogs 2 15.05.2007 11:55
Часовой пояс GMT +3, время: 12:59.
