Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 24.05.2007, 15:13   #1
ginmur is offline
ginmur
Number sequence problems - Ax3 sp3
Hi all,
as my russian is not as good, I couldn;t find if something is already posted on this topic here.
But my problem is that number sequencies are not working correctly. When creating new lines in general journal, sometimes a strange number is used for number sequence. However it is in the NS format, it is not the number specified in the next field in NS. The solution is to delete this voucher from NS list table and then the correct number is used. This NS is set up as continuous, which is correct.
From my point of view it seems to be a bug, but could't find any hotfix or another solution to fix this issue.
Could someone help?
daxcoder: Number Sequence Framework Part I Blog bot DAX Blogs 0 31.01.2008 15:00
Куда пропадают лицензии в Ax3.0 SP3 KR2? falcon65 DAX: Администрирование 2 10.05.2007 09:55
Arijit Basu: New Number Sequence for new AX Module Blog bot DAX Blogs 1 16.04.2007 10:39
Ax3.0 SP3 CIS: Журнал накладных и российские договора (ошибка) mpa DAX: Функционал 2 11.10.2004 15:14
Warning: Number sequence for network is not initialized Mish DAX: Администрирование 13 02.07.2003 15:40
Часовой пояс GMT +3, время: 20:59.
