Старый 17.01.2008, 03:30   #1
axStart: AXC configuratied SharePoint AX configuration.
Источник: http://axstart.spaces.live.com/Blog/...C0A0!241.entry
If you use an installation related to the installation manuals of AX. SharePoint will connect to AX with the current .net configuration. It would be better if it was acx configuration related. Well I some small tricks that I would like to share with you. It is possible to adapt your web.config file in IIS. At bellows box in the [FONT='Verdana','sans-serif'] group.[/FONT]
[FONT='Verdana','sans-serif'][/FONT]
Next at the following code to system.web file on IIS
[FONT='Verdana','sans-serif']     [/FONT]
axStart: Adding your AX pictures to you SharePoint Site Blog bot DAX Blogs 0 10.01.2008 23:17
axStart: Checklist when AX is not working with SharePoint Blog bot DAX Blogs 0 10.01.2008 23:17
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 01:45.
