Старый 08.02.2008, 00:10   #1
C# and AX Development: How show a popup menu in AX/Axapta
Источник: http://olondono.blogspot.com/2008/02...-axaxapta.html
In the following sample, I have duplicated the sysAOT form, and I have overrode the context method for the tree control. Here the code to show the system context menu for any selected treeNode.
PopupMenu       popupMenu;
SysContextMenu  sysContextMenu;
int idx = tree.getFirstSelected();
TreeNode treeNode = tree.getItem(idx).data();
// add some custom menu items
int editMenu;
int choice;
// current selected treeNode is valid ?
if (treeNode == null)
    return;
// create the SysContextMenu for this TreeNode
sysContextMenu = new SysContextMenuTreeNode(treeNode);
// System API call to build the popup menu
popupMenu = sysContextMenu.buildMenu(this.hWnd());
// Add a custom edit menu
popupMenu.insertBreak();
editMenu = popupMenu.insertItem("Edit");
// showing menu
choice = popupMenu.draw();
// Showing and processing this popupMenu
if (!sysContextMenu.runMenu(choice, sysContextMenu))
    if (choice == editMenu)
        SysInfoAction_Editor::newOpen(treeNode.treeNodePath()).run();
But, looking in depth, I found that the sysAotFind form can be used to get some practical sample on how we can create our custom popup menu. Here an adapted version of that code to the previous SysAOT2 form(method context within control tree):
// We want to build, a popup menu, with a custom submenu and another
// sysContextMenu as submenu (add-ins menu item)
PopupMenu       popupMenu      = new PopupMenu(this.hWnd());
PopupMenu       copyMenu       = new PopupMenu(this.hWnd(), popupMenu);
PopupMenu       subSysContextMenu;
// Menu options
int             open;
int             editMethod;
int             copyName;
int             copyPath;
int             copyFullPath;
int             copyAll;
int             choice;
int             find;
    return;
// Building the menu
open = popupMenu.insertItem("Open");
editMethod = popupMenu.insertItem("Edit");
copyName        = copyMenu.insertItem("Copy Name");
copyPath        = copyMenu.insertItem("Copy Path");
copyFullPath    = copyMenu.insertItem("Copy FullPath");
copyAll         = copyMenu.insertItem("Copy All");
popupMenu.insertPopupMenu("Copy", copyMenu);
find = popupMenu.insertItem("Find");
subSysContextMenu = sysContextMenu.buildMenu(this.hWnd(), popupMenu);
popupMenu.insertPopupMenu("Add-ins", subSysContextMenu);
// Now, showing the popup menu
// processing option
    switch (choice)
        case open:
            // to implement
            break;
        case editMethod:
            break;
        case find:
            // to implement
            break;
        case copyName, copyPath, copyFullPath, copyAll:
            // to implement
            break;
Часовой пояс GMT +3, время: 03:32.
