Старый 24.02.2008, 17:40   #1
Ruslan Goncharov: Posting InventJournal from X++
Источник: http://rusgon.blogspot.com/2008/02/p...al-from-x.html
Once I was faced the problem to post InventJournal from code.
At first glance it's easy. Let's open AOT. Then we find corresponding Menu Item in \Menu Items\Action\InventJournalPost. Open class InventJournalCheckPost... And looking at main() method of this class we are coming to conclusion that this class is tightly tied to the journalForm. What's a pity!
So let's try to write own code.
static void main(Args args)
        InventJournalCheckPost journalCheckPost;
        journalForm journalForm;
        journalForm = journalForm::fromArgs(args);
        journalCheckPost = InventJournalCheckPost::newFromForm(args,journalForm);
        journalForm.runbaseMainStart();
        if (!journalCheckPost.PROMPT())
                if (! journalCheckPost.BatchInfo().parmBatchExecute())
                        journalForm.runbaseMainCancel();
                return;
        try
                journalCheckPost.run();
                journalForm.runbaseMainEnd(journalCheckPost,false);
        catch (Exception::Error)
                journalForm.runbaseMainEnd(journalCheckPost,true);
First of all we need to get rid of journalForm.
Let's rewrite newFromForm() method. The parameters wich passing into this method are used to achieve InventJournalTable. So we may just pass InventJournalTable into our new method.
JournalCheckPost getJournalCheckPost(InventJournalTable _inventJournalTable)
        // \Menu Items\Action\InventJournalPost
        switch(inventJournalTable.journalType)
                case InventJournalType::Movement:
                case InventJournalType::LossProfit:
                case InventJournalType::Transfer:
                case InventJournalType::BOM:
                case InventJournalType::Count:
                case InventJournalType::project:
                case InventJournalType::Asset:
                        journalCheckPost_Mov = InventJournalCheckPost_Movement::newJournalCheckPost(
                        false,true, JournalCheckPostType::Post, _inventJournalTable.tableId,                    _inventJournalTable.journalId);
                        // journalTransData = _journalForm.JournalTransData();
                        // if (journalTransData)
                        // journalCheckPost_Mov.parmVoucher(journalTransData.journalTrans().voucher);
                return journalCheckPost_Mov;
                case InventJournalType::TagCounting:
                        journalCheckPost = InventJournalCheckPost_Tag::newJournalCheckPost(
                        false, true, JournalCheckPostType::Post, inventJournalTable.tableId,                    _inventJournalTable.journalId);
                return journalCheckPost_Tag;
Look at JournalFormTable class. It extends journalForm class.
Inside of runbaseMainStart() method we may find following line
journalTableData.updateBlock(JournalBlockLevel::None,JournalBlockLevel::System,false);
inside of runbaseMainCancel() method:
journalTableData.updateBlock(JournalBlockLevel::System,JournalBlockLevel::None,false);
and inside of runbaseMainEnd() method:
That's enough. Now we may rewrite main() method:
// Posting start. According to \Classes\InventJournalCheckPost
// journalForm.runbaseMainStart();
        journalTableData::updateBlockServer(
        inventJournalTable, JournalBlockLevel::None, JournalBlockLevel::System, false);
        journalCheckPost = getJournalCheckPost(inventJournalTable);
                        // journalForm.runbaseMainCancel();
                        inventJournalTable, JournalBlockLevel::System, JournalBlockLevel::None, false);
                return;
        try
                // journalForm.runbaseMainEnd(journalCheckPost,false);
                // journalForm.runbaseMainEnd(journalCheckPost,true);
                inventJournalTable, JournalBlockLevel::System, JournalBlockLevel::None, true);
// Posting end
Finally, we are ready to write our remarkable job:
static void JobInventJournalPost(Args _args)
        InventJournalCheckPost_Movement journalCheckPost_Mov;
        InventJournalCheckPost_Tag journalCheckPost_Tag;
        InventJournalTable inventJournalTable;
        InventJournalId inventJournalId = 'Inv002372';
                switch(_inventJournalTable.journalType)
                                false, true, JournalCheckPostType::Post, _inventJournalTable.tableId,                           _inventJournalTable.journalId);
        inventJournalTable = InventJournalTable::find(inventJournalId);
        if(inventJournalTable)
                        return;
                try
                // Posting end
inventjournal, программно, разноска
Ruslan Goncharov: A few words about sorting codes Blog bot DAX Blogs 0 18.02.2009 21:05
Ruslan Goncharov: From Microsoft Dynamics AX Programming newsgroup tricks Blog bot DAX Blogs 0 24.05.2008 00:08
Ruslan Goncharov: Dynamic enabled() property for StringEdit and arrows Blog bot DAX Blogs 0 18.04.2008 20:05
Часовой пояс GMT +3, время: 03:04.
