Старый 05.04.2008, 19:12   #1
JOPX: Changing the default maximum size of SharePoint WSP files
Источник: http://jopx.blogspot.com/2008/04/cha...m-size-of.html
If you are not using the SharePoint WSP builder tool and you are building your WSP's using makecab.exe then this is something usefull to know. By default the size of the wsp will be limited to 360 KB (which is the max. size of 5.25'' floppies from the good old days). You can however change this by adding the following to your .ddf file:
.Set MaxCabinetSize=0
.Set FolderSizeThreshold=0
.Set CabinetFileCountThreshold=0
.Set FolderFileCountThreshold=0
Tags van Technorati: sharepoint+2007,moss+2007,sharepoint,microsoft,development,WSP
Параметр Maximum buffer size в настройках AOS Bishop DAX: Администрирование 4 15.03.2016 16:49
Fred Shen: Add an AX user to be a memebr of Sharepoint site group Blog bot DAX Blogs 0 26.08.2008 11:05
JOPX: Why Microsoft Dynamics AX 2009 might interest SharePoint developers ... Blog bot DAX Blogs 0 21.08.2008 01:05
JOPX: Dynamics AX 2009 and Windows 2003 Server and default keyboard layout - logon screen Blog bot DAX Blogs 0 06.05.2008 06:12
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
Часовой пояс GMT +3, время: 03:40.
