Старый 30.04.2008, 16:05   #1
axaptapedia: Autozip for Dax 4.0
Источник: http://www.axaptapedia.com/Autozip_for_Dax_4.0
Summary: /* Download */
== Autozip 1.0 for Dynamics Ax 4.0 ==
Autozip helps you to export and import xpo's as zip files. Here is a short
brief of how to install it.
=== Download ===
[[Media:Autozip_V1.0.zip]]
=== Use of Autozip ===
Autozip let's you automatically zip the exported xpo and similary import an
zip file rather a xpo.
=== Installation ===
1. Dowload and Extract the zip file from the following place...
2. Add the dll file from the extract to your bin directory and simlarly
add an reference to it in your AOT
3. Now import the XPO.
4. Autozip is ready to use.
=== Zip during Export ===
1. Just click the zip file option while u export.
[[Image:Autozip.jpg]]
2. It will export one .xpo file and one .zip file
=== Import a zip file ===
1. Just open any drive and point to a zip file that contains xpo's
(doesn't matter if it contain other files inside it also)
2. That's all ... all xpo files inside the zip will be imported.
=== Using this for your developments ===
Yes you can use it. Please refer to the Job "JobAutozip" along with
this project to know about it.
=== Missing Feature ===
1. If your zip file extracts them as folders and puts the xpo inside folders,
the system will not find them. (This fill be fixed in the next release)
=== Enhancements ===
1. An option to delete the .xpo file which get's exported.
=== Feed back ===
Do let me know your comments @ Kamal's space http://casperkamal.spaces.live.com
or write casperkamal@gmail.com
== Author ==
'''Kamalakannan'''
axaptapedia: Table Methods Generator Blog bot DAX Blogs 0 13.02.2009 02:05
axcoder: PowerShell + Ax Blog bot DAX Blogs 1 09.01.2009 18:05
axaptapedia: Load Web Documents Blog bot DAX Blogs 1 03.01.2009 23:50
axcoder: AxPath is supported by axaptapedia Blog bot DAX Blogs 0 11.05.2007 10:00
Часовой пояс GMT +3, время: 17:20.
