Старый 14.05.2008, 20:05   #1
msdynamicsax: BI with timeXtender
Источник: http://msdynamicsax.wordpress.com/20...h-timextender/
timeXtender is a developer tool for implementing Business Intelligence projects fast and efficient and still use the Microsoft SQL platform as a basis engine.
We have used timeXtender in projects and have found that it reduces development time to a minimum as it is very simple to use but still can help you set up advanced datawarehouses and cubes.
You can use several datasources to extract data from and put into your datawarehouse and they have adapters for both Dynamics Ax and NAV.
Check out the facts here: www.timextender.com
Dynamics AX: Dynamics BI: BI for the Masses Blog bot DAX Blogs 0 17.02.2009 01:05
msdynamicsax: Dynamics Ax 2009 SDK Blog bot DAX Blogs 0 13.08.2008 14:05
msdynamicsax: Task Recorder Blog bot DAX Blogs 0 04.04.2008 11:05
msdynamicsax: User Interface Blog bot DAX Blogs 0 04.04.2008 11:05
Часовой пояс GMT +3, время: 13:09.
