Старый 24.06.2008, 18:05   #1
axaptapedia: Exception handling
Источник: http://www.axaptapedia.com/Exception_handling
Summary: Added enums and example
<div>When execution a string of code, there is a risk that something may go wrong. Exception handling lets you handle system errors by your own code.
==Try and Catch==
If you are able to predict a block of code, where an exception will occur under certain circumstances, you can use the '''try''' command:
try
// Block of code that may fail
catch (exception::error)
// Do something about this error
==Retry==
If you enter '''Retry''' in the '''catch''' block the '''try''' block is executes once more, but be carefull as this can result in a never-ending loop.
==Catch enums==
{| border="1"
!Enum (exception::)
!Description
|Info
|Warning
|Deadlock
|Error
|Internal
|Break
|DDEerror
|Sequence
|Numeric
|CLRError
|CodeAccessSecurity
|UpdateConflict
|UpdateConflictNotRecovered
==Example==
static void TryCatchTest(Args _args)
Map m = new Map(types::Integer, types::String);
str s;
int i;
m.insert(0,"Zero");
m.insert(1, "First");
m.insert(2, "Second");
m.insert(4, "Fourth");
for (i=0;i
Issues concerning X++: Exception handling and transactions Blog bot DAX Blogs 1 14.02.2009 00:46
dax-lessons: Document Handling in AX - setup and Example Blog bot DAX Blogs 0 27.08.2007 23:00
channel9: Exception handling in X++ Blog bot DAX Blogs 18 27.02.2007 10:54
casperkamal: Channel 9 Update - Screen Cast Exception handling Blog bot DAX Blogs 0 31.01.2007 21:00
SysDictCoder: Axapta error handling and database transactions Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 20:46.
