Старый 30.07.2008, 11:51   #1
AlekseyS is offline
AlekseyS
Проблема запуска MS WORD
Добрый день!
Подскажите столкнулся с такой проблемой:
Делаю plug-ins который по событию создания нового account будет создавать документ MS Word)
Code:
using System;
using Microsoft.Crm.Sdk;
using Microsoft.Crm.SdkTypeProxy;
using Microsoft.Office.Interop.Word;
using Microsoft;
namespace Microsoft.Crm.Sdk.Walkthrough
public class AccountCreateHandler: IPlugin
public void Execute(IPluginExecutionContext context)
DynamicEntity entity = null;
#region Verify execution context
// Check if the input parameters property bag contains a target
// of the create operation and that target is of type DynamicEntity.
if (context.InputParameters.Properties.Contains("Target") &&
context.InputParameters.Properties["Target"] is DynamicEntity)
// Obtain the target business entity from the input parmameters.
entity = (DynamicEntity)context.InputParameters.Properties["Target"];
// Verify that the entity represents an account.
if (entity.Name != EntityName.account.ToString()) { return; }
else
return;
#endregion Verify execution context
try
//System.Console.WriteLine("Opening a new Word document...");
MSWord.openDocument();
//System.Console.WriteLine("Writing stuff to the document.");
MSWord.writeStuff("This is a test.");
//System.Console.WriteLine("Saving the document and exiting.");
MSWord.closeDocument(@"c:\done_test.doc");
catch (System.Web.Services.Protocols.SoapException ex)
throw new Exception(ex.Detail.ToString(), ex);
class MSWord
public static ApplicationClass word = new ApplicationClass();
public static Document doc = null;
public static void openDocument()
word.Visible = true;
object file = @"C:\template.dot"; // blank path = new document
object newTemplate = false;
object docType = 0;
object isVisible = false;
// add a new document based off of the normal.dot template
doc = word.Documents.Add(ref file, ref newTemplate, ref docType, ref isVisible);
doc.Activate();
public static void writeStuff(string what)
System.Console.WriteLine("Total bookmoarks: " + doc.Bookmarks.Count);
foreach (Bookmark bk in doc.Bookmarks)
if (bk.Name == "testbook")
bk.Range.Text = "This is a content of bookmark";
doc.Tables[1].Rows[1].Cells[1].Range.Text = "Hello word";
//doc.Tables[0].Cell(0, 0).Range.Text = "hello from C#";
word.Selection.TypeText(what);
public static void closeDocument(string path)
object filePath = (object)path;
object False = false;
object True = true;
object blank = "";
object format = WdOpenFormat.wdOpenFormatAuto;
//object encoder = Office.MsoEncoding.msoEncodingUSASCII;
object unicode = 65001;
object missing = System.Reflection.Missing.Value;
doc.SaveAs(ref filePath, ref format, ref missing, ref missing, ref missing, ref missing, ref missing,
ref missing, ref missing, ref missing, ref missing, ref missing, ref missing, ref missing, ref missing, ref missing);
word.Quit(ref missing,
ref missing,
ref missing);
После выполнения лог:
# CRM Tracing Version 2.0
# LocalTime: 2008-07-30 00:20:40.4
# Categories:
# CallStackOn: No
# ComputerName: MOSS
# CRMVersion: 4.0.7333.3
# DeploymentType: OnPremise
# ScaleGroup:
# ServerRole: AppServer, AsyncService, DiscoveryService, WebService, ApiServer, HelpServer, DeploymentService
[2008-07-30 00:20:40.4] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread: 8(MSCRM:-NotificationManager.NotificationWatcherThreadProc) |Category: Exception |User: 00000000-0000-0000-0000-000000000000 |Level: Error | NotificationManager.NotificationWatcherThreadProc
at NotificationManager.NotificationWatcherThreadProc()
at ThreadHelper.ThreadStart_Context(Object state)
at ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at ThreadHelper.ThreadStart()
>ThreadAbort Exception in NotificationWatcherThreadProc Thread was being aborted.
[2008-07-30 00:20:40.4] Process: w3wp |Organization:00000000-0000-0000-0000-000000000000 |Thread: 8(MSCRM:-NotificationManager.NotificationWatcherThreadProc) |Category: Platform |User: 00000000-0000-0000-0000-000000000000 |Level: Error | NotificationManager.NotificationWatcherThreadProc
>NotificationWatcherThreadProc Stopped.
Подскажите, в чем может быть проблема. Кучу всего уже пробовал пока 0 решения.
Последний раз редактировалось AlekseyS; 31.07.2008 в 13:05.
Старый 30.07.2008, 13:51   #2
AlekseyS is offline
AlekseyS
plug-ins не работает
Старый 30.07.2008, 14:37   #3
IgorF is offline
IgorF
Учаснег
Аватар для IgorF
307 / 37 (2) +++
насколько я знаю, формирование документа WORD не работает в контексте сервера, а именно на сервер CRM и выполняется plug-in.
Старый 30.07.2008, 17:08   #4
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Может на сервере нет Office?
Старый 30.07.2008, 18:52   #5
AlekseyS is offline
AlekseyS
Стоит Office 2007.
+ в dcomcnfg добавил юзера Network Service
Старый 31.07.2008, 13:00   #6
AlekseyS is offline
AlekseyS
Заметил, что если удалить файл шаблон с диска с… то СРМ начинает ругаться что не может найти файл. Значить проблема в запуске самого WORD на сервер? Может кто что посоветует?
Если просто на сервере запустить шаблон то все открывает.
Старый 31.07.2008, 13:33   #7
Артем Enot Грунин
Вот ссылка на статью, как работать с Excel через сервер, может быть что-то подчерпнете:
http://blogs.msdn.com//crm/archive/2...xcel-2007.aspx
Старый 01.08.2008, 01:25   #8
AlekseyS is offline
AlekseyS
Отловили ошибку L(((((
На строке:
зависает и все…L(((((
Хелп J
П.С. проблема именно с Documents.Add поскольку просто .тхт создает без проблем
Старый 01.08.2008, 14:00   #9
AlekseyS is offline
AlekseyS
последний ломтик надежды - запустить аппликейшен пул от другого пользователя, привилегированного. Вот только как это сделать, чтобы не отвалился CRM???
Старый 05.08.2008, 00:52   #10
AlekseyS is offline
AlekseyS
Всем спасибо! Решил проблему использовал XmlDocument.
Старый 05.08.2008, 08:42   #11
Артем Enot Грунин
Не поясните более развернуто?
Старый 05.08.2008, 12:52   #12
AlekseyS is offline
AlekseyS
//Create a new annotation object, which represents the notes you see in CRM.
annotation newsgroupsNote = newannotation();
//The annotation's body. It is displayed in the notes view.
newsgroupsNote.notetext = "Document"; // - \r\n
//The objectid specifies to which business object the annotation belongs.
newsgroupsNote.objectid = newLookup();
newsgroupsNote.objectid.type =
EntityName.account.ToString();
newsgroupsNote.objectid.Value =
newGuid(context.OutputParameters.Properties["id"].ToString());
//The objecttypecode specifies the type of the parent entity.
newsgroupsNote.objecttypecode = newEntityNameReference();
newsgroupsNote.objecttypecode.Value =
//The subject.
newsgroupsNote.subject = "You should look ready document";
//Create the annotation
ICrmService service = context.CreateCrmService(true);
Guid annotID = service.Create(newsgroupsNote);
account ent = (account)service.Retrieve(EntityName.account.ToString(),newGuid(context.OutputParameters.Properties["id"].ToString()), newAllColumns());
annotation oAnnotation = newannotation();
XmlDocument doc = newXmlDocument();
doc.Load(
... что то делаем (кому что надо )
doc.Save(@"..." + name); // .doc
StreamReader reader = newStreamReader(@"..." + name);
string input = GetBase64StringFromFile(@"..." + name);
TargetUpdateAnnotation tua = newTargetUpdateAnnotation();
Key oKey = newKey();
oKey.Value = annotID;
oAnnotation.annotationid = oKey;
oAnnotation.filename =
oAnnotation.filename = name
oAnnotation.mimetype =
"application/xml";
oAnnotation.documentbody = input;
CrmNumber oNumber = newCrmNumber();
oNumber.Value = 4;
oAnnotation.filesize = oNumber;
tua.Annotation = oAnnotation;
UpdateRequest req = newUpdateRequest();
req.Target = tua;
UpdateResponse resp = (UpdateResponse)service.Execute(req);
Старый 05.08.2008, 12:54   #13
AlekseyS is offline
AlekseyS
Вот так и сделали для 2003 - 2007 worda
Старый 05.08.2008, 23:16   #14
Артем Enot Грунин
Ээээ. Не вкурил где тут создается документ ворд по шаблону? Или вы отказались от первоначального плана в пользу более простого решения - добавления примечания?
Старый 06.08.2008, 23:52   #15
AlekseyS is offline
AlekseyS
просто шаблон в хмл
Старый 07.08.2008, 00:00   #16
AlekseyS is offline
AlekseyS
Google:
...Поддержка XML в Word 2003 - одно из наиболее впечатляющих достижений Microsoft Office 2003. Благодаря использованию XML данные Word становятся свободными, незаблокированными, и их легко модифицировать. Кроме того, XML упрощает обмен информацией между документами, базами данных и другими приложениями.
http://www.gotdotnet.ru/LearnDotNet/...ces/30939.aspx
word
Проблема активации MS Dynamics CRM Likefire Dynamics CRM: Администрирование 27 10.12.2009 14:33
Проблема с MS CRM Asynchronous Processing Service Camena Dynamics CRM: Администрирование 15 03.04.2009 14:51
Проблема при создании мероприятия ShurikEv Dynamics CRM: Функционал 2 03.11.2008 18:26
Microsoft Dynamics CRM Team Blog: MS Word Proposal for CRM Online Blog bot Dynamics CRM: Blogs 0 12.08.2008 04:07
Проблема при установке MS CRM 3.0 Ошибка в версии SQL alexs_ua Dynamics CRM: Администрирование 3 30.01.2006 18:18
Часовой пояс GMT +3, время: 03:35.
