Старый 04.08.2008, 03:16   #1
C# and AX Development: Configuring Analysis Services 2005 for AX
Источник: http://olondono.blogspot.com/2008/08...-2005-for.html
For use Analysis Services 2005 with Dynamics AX, we need to ensure that DSO (Decision Support Objects) is well configured. Take a look to the following post for more information (NOTE: this post refers to Project 2007 but it is applicable to AX):
http://www.pptspaces.com/msprojectre...ost.aspx?ID=25
Important steps:
1. Ensure you have installed the following components:
- Microsoft SQL Server Native Client
- Microsoft SQL Server 2005 Management Objects Collection
- Microsoft SQL Server 2005 Backward Compatibility Components
2. Create the old style shared folder (MSOLAPRepository$), normally in C:\Program Files\Microsoft SQL Server\MSSQL.2\OLAP\DSO9 for example.
- Share this folder as MSOLAPRepository$.
- Se permissions for EveryOne or any OLAP users group as Change (they need permissions to modify folder's content).
- Set Full control to SQLServer2005MSOLAPUser$SERVERNAME$MSSQLSERVER. This user can be located in the ServerName instance.
3. Copy msmdrep.mdb to this location (DSO9). You can get a copy of this file from http://www.pptspaces.com/msprojectre...es/msmdrep.zip
4. Configure data access connection and locks folders: (Open the Analysis Services's properties dialog using the SQL Server Mananagement studio and selection the option "Show Advance (All) properties")
- Configure the DSO\LocksDirectory property with the correct path, ex. C:\Program Files\Microsoft SQL Server\MSSQL.2\OLAP\DSO9
- Configure the DSO\ RemoteLocksDirectory property as \\ServerName\MSOLAPRepository$\. Here is the tip different from the original post.
- Configure the DSO\ RemoteRepositoryConnectionString selecting the Microsoft Jet 4.0 OLE DB Provider but setting the path as \\ServerName\MSOLAPRepository$\msmdrep.mdb. Here is another difference from the original post.
- Configure the DSO\ RepositoryConnectionString property but in this case, use the full local path for the msmdrep.mdb file, ex. C:\Program Files\Microsoft SQL Server\MSSQL.2\OLAP\DSO9\msmdrep.mdb
Thats all, try it, transfer and process some cubes.
olap
Часовой пояс GMT +3, время: 22:16.
